2 Pages12>
Offline marks2c
#1 Posted : 08 April 2022 09:17:40(UTC)
marks2c
New Zealand
Was thanked: 2 time(s) in 1 post(s)
I've been unable to solve this (pardon the pun):
20220408 Voltage Divider Solve.sm (37kb) downloaded 10 time(s).
Any thoughts?
Thank you in advance.
Mark
Edited by moderator 09 April 2022 14:33:16(UTC)  | Reason: Not specified
Offline overlord
#2 Posted : 08 April 2022 15:25:46(UTC)
Turkey
Was thanked: 290 time(s) in 204 post(s)
You have defined R2, maybe that's why you can't solve.
First you need to be sure calculation variable cleared.
And if you defined your function, it will also prevent the solution.
Some remembrance for smath solvers;
solve(), roots() and al_nleqsolve() won't work directly with units.
You have to trick them for units, adding into equations.
Maple solve and FindRoot() can work with units.
I also included mathblock method, which relies on FindRoot().
If your root is beyond -20,20 you have to specify it for roots() and solve().
Unless you didn't already change Root Ranges in options.
And you also have to guess a starting point for FindRoot().
20220408 Voltage Divider Solve_v2.sm (51kb) downloaded 10 time(s).
#3 Posted : 08 April 2022 15:32:28(UTC)
Was thanked: 910 time(s) in 738 post(s)
Make it SI ...
Offline overlord
#4 Posted : 08 April 2022 15:41:34(UTC)
Turkey
Make it SI ...
That is not an SI unit you clown.
It is simply equal to 1, not (kg*m^2)/(A^2*s^3).
#5 Posted : 08 April 2022 16:08:47(UTC)
Originally Posted by: overlord Go to Quoted Post
That kΩ is not an SI unit
Offline Kenny Lemens
#6 Posted : 08 April 2022 16:09:50(UTC)
Kenny Lemens
Rank: Member
Was thanked: 9 time(s) in 7 post(s)
Resistive Voltage Divider Solve for R2 (or any variable)
Greetings Mark,
For your first part, you can copy and paste this formula (solved for R2):
Code:
R2:{R1*V.out}/{V.in-V.out}
For your second part, please reference the following forum topic: https://en.smath.com/for...quations-with-Solve.aspx
There is a healthy discussion of various methods to solve for an unknown variable.
Hope that Helps!
-Kenny Lemens, P.E.
Offline overlord
#7 Posted : 08 April 2022 16:16:47(UTC)
Turkey
Your kΩ is not SI unit dumbass, which has value of 1.
The one you have defined as 1, that you wrote kΩ:1.
SMath kΩ of course is a SI unit, not your goofer kΩ.
If you claim your kΩ is suitable to SI, just share us the multiplication of "your" kΩ with A^2.
A is Ampere if I could help your unitless brain. For your information, result is kW.
I will just wait your gibberish reply and answer it with a new insult.
#8 Posted : 08 April 2022 21:19:29(UTC)
As well, maple will solve. Maple is unit-less.
Smath w/o maple is missing the best, particularly in
Process Control & Instrumentation.
Why not a new thread for your Thermodynamic/Chemical project.
Cherrs ... Jean.
Offline Razonar
#9 Posted : 08 April 2022 21:48:02(UTC)
Razonar
Uruguay
Was thanked: 560 time(s) in 364 post(s)
Of course not. Maple units help page: https://www.maplesoft.com/index.html?path=units
Either Wolfram Mathematica:
My old units package, for version 5.0: https://library.wolfram....ocenter/MathSource/5511/
New Quantity package: https://reference.wolfra...nguage/ref/Quantity.html
Offline marks2c
#10 Posted : 08 April 2022 22:25:15(UTC)
marks2c
New Zealand
Thank you all so much. The help is very greatly appreciated.
Mark
Offline marks2c
#11 Posted : 08 April 2022 22:42:43(UTC)
marks2c
New Zealand
Greetings Mark,
Code:
Hope that Helps!
-Kenny Lemens, P.E.
Thank you so much Kenny. The direct 'no solving required' approach is perfect.
Again, thank you.
Mark
#12 Posted : 09 April 2022 02:37:47(UTC)
Originally Posted by: Razonar Go to Quoted Post
Of course not
Of course NOT !
Inst_Valve Sizing CV series.sm (7kb) downloaded 10 time(s).
Offline overlord
#13 Posted : 09 April 2022 04:17:53(UTC)
Turkey
Of course NOT !
Of course it is, even your example can solve with SI units.
If you were not a duffer and enter units as they should be, you would witness the miracle.
Look Jean. No magic numbers, no conversion factors, only numbers and units.
Units can easily be shown in their kilo, mega, centi, mili form by using SI.
Declaring them as 1 or creating same name units is just pure stupidity.
I get it, you learn to calculate when units are not a thing for softwares back then.
But time is changed. Softwares have unit supports now, it is the correct path to use units.
You simply resist to learn new things, in every situation, and encourage your ignorance to new users.
Which means you don't have primer feature of a scientist or engineer.
Offline uni
#14 Posted : 09 April 2022 12:44:26(UTC)
uni
Was thanked: 1163 time(s) in 672 post(s)
To be completely honest, I helped Maple understand units. The plugin uses the old 6th version of the program, and support for units appeared in the 7th version.
Russia ☭ forever
Viacheslav N. Mezentsev
#15 Posted : 09 April 2022 16:38:56(UTC)
About that long discussion Si and Solve,
you can get lot more solving on the canvas.
Willing difficult Titration, more convivial Pitot.
By same token: thanks Viacheslav for maple/Units
Titration.sm (27kb) downloaded 8 time(s).
Offline overlord
#16 Posted : 10 April 2022 06:16:13(UTC)
Turkey
Thanks for the unit support. So original maple has unit support since 2001.
And smath maple plugin has also unit support, that is what concerns us, which proves Jean is wrong again.
Offline uni
#17 Posted : 10 April 2022 10:11:22(UTC)
uni
Updated (maple()). Fixed issue with trigonometric functions, added support for units.
A post about this can be found here.
And how it works:
Click to enlarge
In Maple units are passed as undefined variables wrapped in single quotes. Therefore, in fact, the SMath does all the work with units. This happens implicitly. But Maple can also work with them, as with symbolic variables.
Edited by user 10 April 2022 10:18:07(UTC)  | Reason: Not specified
Russia ☭ forever
#18 Posted : 10 April 2022 15:44:02(UTC)
Viacheslav can confirm the date maple/Units.
Offline overlord
#19 Posted : 10 April 2022 15:49:18(UTC)
Turkey
Do your own research.
https://www.maplesoft.com/products/maple/history/pastversions_maple7.aspx
And according to this link uni provided, maple plugin has unit support for 9 years.
https://en.smath.com/forum/yaf_postst1025p8_Maple-Tools.aspx
Just admit you don't know what you are talking about.
#20 Posted : 10 April 2022 15:59:19(UTC)
Smath first version 2006_11_13
Mathcad 8 Pro, 11 is a Maple subcontract.
May be old collab Alvaro can confirm maple 2001 supported units ?
2 Pages12>
