Offline Mido0
#1 Posted : 05 April 2022 21:45:27(UTC)
Mido0
Rank: Member
hi,
I used the Solve function a lot before but for some reason it does not work for this simple example.
I need to get the RayLeigh Damping factors alpha and beta using two frequencies, so two simple simultaneous equations should do it. tried using Solve but no luck.
Does anyone know why it is not solving?
Thanks in advance
Solve.jpg test.sm (6kb) downloaded 7 time(s).
Offline PompelmoTell
#2 Posted : 05 April 2022 22:39:40(UTC)
PompelmoTell
Was thanked: 105 time(s) in 89 post(s)
test_sergio.sm (9kb) downloaded 19 time(s).
Edited by user 05 April 2022 22:45:15(UTC)  | Reason: Not specified
on 06/04/2022(UTC)
Offline overlord
#3 Posted : 06 April 2022 00:24:50(UTC)
Turkey
Was thanked: 290 time(s) in 204 post(s)
You can use roots() for your function. And a vectorize() can simplify it.
However, to use Assign() you will need this function to merge vars and solutions.
Assign_without_Maxima Solve().sm (8kb) downloaded 12 time(s).
on 06/04/2022(UTC)
Offline Mido0
#4 Posted : 06 April 2022 04:22:48(UTC)
Mido0
Rank: Member
Thanks Overlord, PompelmoTell, greatly appreciated!!
Offline Kenny Lemens
#5 Posted : 06 April 2022 16:28:07(UTC)
Kenny Lemens
Rank: Member
Was thanked: 9 time(s) in 7 post(s)
Greetings,
Another approach would be to use some elbow grease, you can substitute terms by hand and solve for 𝛼 and 𝛽:
Keypress (You can copy/paste the following into your worksheet):
Code:
α:{2*D*ω.1*ω.2}/{ω.1+ω.2}
β:α/{ω.1*ω.2}
*NOTE: ω.1 and ω.2 shown above are variables with subscript, they are not vectors ω[1 and ω[2; You should be able to substitute ω.1 for ω[1 if that serves your purposes.
- Kenny Lemens, P.E.
thanks 1 user thanked Kenny Lemens for this useful post.
on 06/04/2022(UTC)
Offline Ber7
#6 Posted : 06 April 2022 17:40:36(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
If the damping coefficients are denoted by α1 and α2, you can use the function al_nlegsoive
test.sm (7kb) downloaded 9 time(s).
thanks 2 users thanked Ber7 for this useful post.
on 06/04/2022(UTC),  on 06/04/2022(UTC)
#7 Posted : 07 April 2022 17:08:53(UTC)
Was thanked: 910 time(s) in 738 post(s)
on 07/04/2022(UTC)
#8 Posted : 07 April 2022 19:43:03(UTC)
... more in there from native Smath code.
Solve FindRoot FORUM.sm (11kb) downloaded 8 time(s).
Offline overlord
#9 Posted : 07 April 2022 23:27:55(UTC)
Turkey
solving with uni's latest addition mathcad blocks;
you wouldn't need Eq: actually, but it can be shown.
mathblock.sm (6kb) downloaded 8 time(s).
Edited by user 07 April 2022 23:29:29(UTC)  | Reason: Not specified
on 10/04/2022(UTC)
Offline overlord
#10 Posted : 08 April 2022 00:19:34(UTC)
Turkey
I think this is the most sophisticated method of my way.
It can get unknowns from equation, solve them.
In the end assigns numerical values to unknowns.
You don't need to define alpha or beta or any variable.
All process is automatic.
mathblock_v2.sm (6kb) downloaded 11 time(s).
There is also this way for guess define.
Edited by user 08 April 2022 01:58:41(UTC)  | Reason: Not specified
Offline Ber7
#11 Posted : 08 April 2022 08:19:42(UTC)
Ber7
Israel
This is good, but for a system of linear equations(our case), the guess can be arbitrary.
Edited by user 08 April 2022 08:30:49(UTC)  | Reason: Not specified
Offline mkraska
#12 Posted : 09 April 2022 02:04:07(UTC)
mkraska
Was thanked: 955 time(s) in 606 post(s)
And finally a version with Solve() and list injection region:
mathblock_Solve.sm (5kb) downloaded 11 time(s).
on 09/04/2022(UTC)
#13 Posted : 11 April 2022 15:57:44(UTC)
Kenny Lemens
Rank: Member
Greetings,
If plugins are considered, you can also consider the use of Maple:
In the image I posted, the 'equal sign' shown on those two equations are actually symbolic equals; keypress: [ctrl] + [.] instead of keypress [=].
Kenny Lemens, P.E.
Offline Razonar
#14 Posted : 11 April 2022 22:44:08(UTC)
Razonar
Uruguay
Was thanked: 560 time(s) in 364 post(s)
Hi. The isol solution, using only the Mathcad block plugin.
isol_example.sm (69kb) downloaded 20 time(s).
isol_example.pdf (35kb) downloaded 9 time(s).
on 12/04/2022(UTC)
Offline Mido0
#15 Posted : 14 April 2022 18:10:17(UTC)
Mido0
Rank: Member
Thank you all for the feedback, is there a literature or manual to explain the Mathcad block plugin?
Thanks
#16 Posted : 14 April 2022 20:54:00(UTC)
Originally Posted by: Mido0 Go to Quoted Post
Thank you all for the feedback, is there a literature or manual to explain the Mathcad block plugin ?
For that particular example, maple is an algebraic export.
Mathcad block has not yet been exemplified in Smath Community
of what it can do vs what native Smath can't.
Codes Solve.sm (13kb) downloaded 5 time(s).
#17 Posted : 15 April 2022 01:43:45(UTC)
Exercise the Mathcad bloc
Offline overlord
#18 Posted : 15 April 2022 02:19:07(UTC)
Turkey
Thanks
We have what Viacheslav provided us.
There are some samples or functions too which individual users uploaded.
You can look the extension page for some examples.
And there are some samples in forum topic that users posted.
It may be a small bunch, but we try to understand its capabilities.
This feature/plugin is also new to us.
https://en.smath.com/forum/yaf_postst726_Mathcad-Toolbox.aspx
