Offline PWP
#1 Posted : 11 November 2021 01:34:30(UTC)
PWP
Rank: Member
Greetings,
Your program is a dream come true.
Using the scroll wheel to change the values inside numeric up/down boxes is excellent for simulations.
However, it would be even better if we could use ctrl, alt and shift as accelerator keys for this action.
So, ordinary scrolling would change the number by the nominated amount.
Holding, say, ctrl would increase the increment/decrement by 10, alt might change it by 100, shift could alter it by 1000.
This would be even better for simulations.
Thanks, I wish I could do it myself but I can't program. One day, perhaps.
#2 Posted : 11 November 2021 16:35:19(UTC)
This function explorer works nice.
Once setup complete, wheel mouse,
leave in auto-calculations mode.
2D Util Stem SLIDER_TRACK.sm (6kb) downloaded 13 time(s).
on 11/11/2021(UTC)
#3 Posted : 11 November 2021 16:53:59(UTC)
That's a good idea, I think I can do it.
Slider is an alternative for sure, although might not fit fixed-step increments (you have to play a bit with the slider position in that case).
Edited by user 11 November 2021 16:58:35(UTC)  | Reason: Not specified
on 11/11/2021(UTC)
Offline PWP
#4 Posted : 11 November 2021 19:56:51(UTC)
PWP
Rank: Member
Hello Davide,
Thanks for you consideration. One more thought: Perhaps the amounts by which the ctrl, shift and alt keys accelerate scroll wheel changes could be specified in the pop-up attributes panel associated with the numerical up/down slider? Just an idea. I know these suggestions might be difficult. As I've said before, even if no further changes were ever made to SMath Studio it would still be the best thing out there.
#5 Posted : 11 November 2021 20:55:15(UTC)
... refreshed version.
2D Util Stem SLIDER_TRACK.sm (6kb) downloaded 11 time(s).
Offline overlord
#6 Posted : 11 November 2021 22:28:24(UTC)
Turkey
Indeed this is a good idea.
Just when you are out of ideas, a new one comes.
We have same-same key combinations for plot plugins.
If they work there, no reason no to work with Up/Down plugin.
PS: Request was about Up/Down region
Not how to use slider region for plots.
This post is not related with topic.
Edited by user 13 November 2021 13:30:24(UTC)  | Reason: Not specified
#7 Posted : 12 November 2021 12:18:52(UTC)
Yes, it was my first idea too. I'll explore even the possibility to use these "secondary scroll" with a modifier (add/subtract as usual, multiply/divide as alternative)
Offline PWP
#8 Posted : 14 November 2021 19:54:20(UTC)
PWP
Rank: Member
Thanks Davide, That's an even better idea. Again, it would be good if the amounts for the increments and decrements invoked by the accelerator keys across the four primary operations could be definable. Of course, as you've indicated, this already seems to be on your mind. Sorry if I'm suggesting something that you were already going to do (that's annoying), it's just that I'm so eager to see the strongest implementation of this feature.
When it's available, this enhancement will make a massive difference for physics and engineering simulations.
Edited by user 15 November 2021 00:52:55(UTC)  | Reason: Just a brief re-statement of the obvious.
