Offline johnnyontheweb
#1 Posted : 12 October 2021 19:48:43(UTC)
johnnyontheweb
Rank: Member
Was thanked: 3 time(s) in 1 post(s)
Hi all,
I have a lot of old .xmcd files to convert to .sm, but I encounter problems when opening almost all of them, unless I save them in XMCD 12 or 13 and I remove images.
I spent some time to debug the plugin, and I found this:
- images are not always represented as string in base64
- only if format XMCD > 13: there's hell with indeces in function MergeManyArrayPostfix in OpenSaveXMCD.cs - often, index for 'value' array is less than 0.
I have some questions about this plugin:
- is advised version of XMCD 12 or 13?
- if there's limitation on format, can not supported format be blocked?
thanks in advance for such info
#2 Posted : 13 October 2021 14:11:08(UTC)
Hello johnnyontheweb,
That plugin is open to improvements, the main problem is that you should be familiar with both programs to do something.
In general, if there are multiple data types for the same objects would be better to detect the type, then develop alternative functions to read the data, otherwise read a placeholder, nothing, or throw an error. I wouldn't block the entire format just because the indices, better to have something to start from than nothing.
#3 Posted : 13 October 2021 16:08:07(UTC)
johnnyontheweb
Rank: Member
I completely agree on that, the point is nothing except text regions is read in most cases.
A message warning the user to give XMCD <= 13 as input would definitely save a lot of time in trials.
Consider, as a sample, the 2 files attached (they are the same file, with 2 different XMCD formats):
inertias.xmcd (77kb) downloaded 50 time(s).
inertias13.xmcd (61kb) downloaded 41 time(s).
#4 Posted : 14 October 2021 11:58:38(UTC)
Thank you very much, this might help a lot! I'll try to improve the plugin as soon as I can.
#5 Posted : 14 October 2021 12:08:49(UTC)
johnnyontheweb
Rank: Member
You're welcome - please keep in mind that inertias is in format XMCD>13, the other in XMCD = 13.
And please do not comment calculations on principal axes because they're not always right Biggrin
#6 Posted : 02 March 2022 20:55:48(UTC)
johnnyontheweb
Rank: Member
I'm looking forward to see if there's improvements for XMCD plugin, I really need it.
I just want to tell that I noticed another problem in this plugin: if the original .xmcd file has repeted definitions (es. a:=1 more than once), the plugin removes all the occurrences and in the resulting file the variable is lost (no "a" defined at all).
