Joined: 10/12/2009(UTC) Posts: 246 Location: Cali, Colombia Was thanked: 85 time(s) in 65 post(s)
An image to describe the problem:
1 user thanked oscampo for this useful post.
I can confirm. In addition, parenthesis and isolating the unit causes an error
2 users thanked ElSid for this useful post.
on 17/09/2021(UTC), on 17/09/2021(UTC)
Hi. I'm not sure if that error is a bug or a feature. Because it prevent an unusual task: using degrees scale temperature (those that have an offset) in a multiplication, where the usual is using the "new" Delta scale temperatures. I take my time to understand why it's neccesary to use Delta's, but get convinced after some good Martin's explanations ( here). This image shows why I think that: Best regards. Alvaro.
I agree with Alvaro. The result is actually correct. I do believe it's still a bug, however, as you can add/subtract degC with seemingly strange, but correct, results. Edited by user 17 September 2021 23:32:01(UTC)
