Hi everyone I have to try to solve this equation with maple and solve but I only get the result "Empty stack", Someone knows solve it? Moment_Curvature relationship.sm (941kb) downloaded 15 time(s).
Hi. It seems that you put kd( ... ) instead kd*( ... ) in the maple solver.
Best regards. Alvaro.
Alvaro thanks for you answer but
"kd" is the only value unknown
In the first expression it is kd( ... ). In the second it is kd*( ... ). There the maple answer uses RootOf, I'm guess that because you have another issue in the expression. For instance A.s*Fy have units of Newtons, but the other part not. Best regards. Alvaro.
Originally Posted by: Bruno Choquepata Thanks a lot Alvaro Alvaro is right. Left side of equation is N (kg*m/s^2), right side is J (kg*m^2/s^2). A dimension should be extra or missing in that equation. Probably not correct solution but if you equate units; Regards
1. RootOf expands easily [Example 1] 2. root is undocumented, most precious for dual solver [Example 2] 3. allvalues ... most precious in invlaplace [Example 3] Maple RootOf Example.sm (39kb) downloaded 24 time(s).
