2 Pages<12
#21 Posted : 11 June 2021 20:49:26(UTC)
Was thanked: 845 time(s) in 675 post(s)
Sanity checked vs Mathcad 11.
Cuts the mustard a bit finer than first version.
Γ(1,0)="Uncertainty" unsolved.
Offline overlord
#22 Posted : 11 June 2021 20:56:09(UTC)
Turkey
Was thanked: 100 time(s) in 74 post(s)
There is no uncertainty in gamma_r6.
Everything look correct with those numbers.
Γ(1)=1
γ(1,0)=0
Γ(1,0)=1
#23 Posted : 11 June 2021 22:33:56(UTC)
1. Example 3 ... added
2. Uncertainty solved for version not having 0 defined.
Gamma [overlord sr.6].sm (40kb) downloaded 6 time(s).
Offline Razonar
#24 Posted : 12 June 2021 08:20:08(UTC)
Razonar
Uruguay
Was thanked: 400 time(s) in 256 post(s)
Originally Posted by: overlord Go to Quoted Post
3. don't want to disrespect, Alvaro's is a single line awesome code.
4. mine has same algorithm with more features, with faster calculation.
Hi overlord, of course you don't. My codes are mostly pedagogical, not for optimized for speed nor accuracy or something else. It's good to have codes with that.
Offline overlord
#25 Posted : 12 June 2021 16:15:48(UTC)
Turkey
Thanks, inspired by your code using sum(), and eliminating some useless variable definitions;
I have managed to speed up 30% percent under linux. And should be more precise now.
Only the 15th decimal digit may differs, and this is only sometimes.
Regards.
gamma_r7.sm (29kb) downloaded 4 time(s).
Edited by user 12 June 2021 18:31:48(UTC)  | Reason: Not specified
Offline overlord
#26 Posted : 12 June 2021 20:58:22(UTC)
Turkey
Apparently solve() can't read product() too.
Had to change algorithm style for incomplete function.
Hopefully this is the last version.
Well, I have my doubts... (swh)
PS: solvers may not found an answer just because variable names, Razonar's idea implemented.
gamma_r8.sm (30kb) downloaded 3 time(s).
gamma_r8.sm (32kb) downloaded 1 time(s). <---gamma_r8-2 (function variable revision)
Edited by user 13 June 2021 02:02:04(UTC)  | Reason: Not specified
Offline Razonar
#27 Posted : 13 June 2021 02:03:48(UTC)
Razonar
Uruguay
Regards.
The algorithm is valid for Re(z) > 0. See this notes please.
gamma.sm (28kb) downloaded 6 time(s).
#28 Posted : 13 June 2021 02:20:04(UTC)
Can't be more right !
1. Smath Lanczos Davide code is 1/1 Keisan, Mathcad 11.
2. It supports imaginary argument.
3. It supports RootSecant.
4. Confirmed, your last Lanczos does not support RootSecant.
I haven't checked Alvaro suggestion.
#29 Posted : 13 June 2021 02:23:36(UTC)
... just a remark:
Mathsoft suggested use exp(,) instead of e^.
exp(,) more accurate/faster at kernel level.
Offline overlord
#30 Posted : 13 June 2021 07:26:31(UTC)
Turkey
Imaginary numbers supplicated.
Root Secant better than HT Davis. (last digit)
Graphing works for all functions.
Usually all solve methods works.
gamma_r9.sm (37kb) downloaded 6 time(s).
#31 Posted : 13 June 2021 17:18:41(UTC)
Your latest sr.9 is mostly red in SS 6179, takes Eternity.
Who cares ^308 ?
On the other hand, could be damned slow in practical applications.
Because not being built-in in native Smath ... proof:
Lanczos plots Hypergeometric but takes 1 min versus resident Gamma(x).
Why not use Lanczos as given by Davide ?
Offline overlord
#32 Posted : 13 June 2021 21:26:22(UTC)
Turkey
Who cares ^308 ?
- Who cares SMath 6179?
- My algorithm is faster than your examples.
- My Γ(x) prints hypergeom in less than a second, don't need integrated Gamma().
- Because my function has more features, and faster.
Your PC is slow, your SMath_6179 is slow and broken, your examples are slow.
Gamma [H.T. Davis, Lanczos_overlord].sm (63kb) downloaded 5 time(s).
Gamma [H.T. Davis, Lanczos_overlord].pdf (156kb) downloaded 5 time(s).
Edited by user 13 June 2021 21:33:08(UTC)  | Reason: Not specified
Similar Topics
Incomplete Gamma Functions (Bugs & Problems)
by overlord 06/06/2021 14:45:29(UTC)
2 Pages<12
