Offline Raul Menduina
#1 Posted : 04 June 2021 13:27:48(UTC)
Raul Menduina
Spain
Hi all,
I have some custom functions implemented on snippets. I have different ones which i recall when i open a blank smath sheets.
It used to work well but in version 0.99 (build:7822), in fact since the version just before that, there's some type of exception thrown when inserting the snippet.
snippets exception
If i click on continue, everything seems to work ok in the sheet and i do not get the message anymore (unless i try to insert a new snippet)
Thanks in advance,
Find also attached the full exception message
ExceptionMessage_SnippetsBug.txt (12kb) downloaded 8 time(s).
Edited by user 04 June 2021 13:30:01(UTC)  | Reason: Not specified
Offline Andrey Ivashov
#2 Posted : 04 June 2021 20:05:31(UTC)
Was thanked: 1972 time(s) in 661 post(s)
Reproduced. Will fix asap.
Thank you!
on 08/07/2021(UTC)
Offline edupa1087
#3 Posted : 08 July 2021 00:48:29(UTC)
edupa1087
Ecuador
Hello everyone, maybe you could solve the problem, the same thing happens to me every time I enter a snippet I created.
Offline Kenny Lemens
#4 Posted : 01 December 2022 17:57:10(UTC)
Kenny Lemens
Was thanked: 31 time(s) in 18 post(s)
Greetings,
If you are still on v0.99 and would like to avoid this error, there is a work-around: Delete the entry in the "Title" field (or the title filed altogether)
1) Navigate to the *.sm files that contain the snippets (e.g., .../Programs/SMath Studio/snippets)
2) Edit file with a Text Editor
3) Remove the metadata entry of <Title> </Title>
4) Save file
5) Relaunch SMath
- Kenny Lemens, P.E. ᵂᴵ
#5 Posted : 01 December 2022 18:50:56(UTC)
Raul Menduina
Spain
Thank you Kenny,
Andrey just fixed it in the subsequent versions, so it works ok for me since then.
Edited by moderator 01 December 2022 23:18:14(UTC)  | Reason: marked as FIXED
