Offline bricemik
#1 Posted : 02 June 2021 11:06:43(UTC)
bricemik
France
I trie to split string every underscore :
B_net="PM1_to_MM1_gth_vpx_p[0]"
with function :
strsplit(B_net,"_" )=mat("PM1_to_MM1_gth_vpx_p[0]",1,1)
I want to extract here "PM1" and "MM1" with
el(strsplit(B_net,"\005F\" ),1)
el(strsplit(B_net,"\005F\" ),3)
But, the underscore is seen as UTF-16 encoding :
Thanks for your help
Bricemik
Offline Andrey Ivashov
#2 Posted : 02 June 2021 14:35:52(UTC)
Hello. Please use the latest stable SMath Studio version.
Offline bricemik
#3 Posted : 02 June 2021 17:55:13(UTC)
bricemik
France
Thank you for your quick feedback
I would like to take this opportunity to thank you for your tool that I use for a few years ago.
Concerning the trouble, I use the lasted stable Smath Studio version : 0.99 build 7822
I import string from a csv file.
The strplit don't recognize the underscore.
However, the findstr does
If I use the strrep function to replace the underscore by the underscore in the string, the strplit recognize the underscore.
Please see below the extract :
text=mat("MM1_To_PM1_presence",1,1)
b_net:el(text,1)="MM1_To_PM1_presence"
strsplit(b_net,"\005F\" )=mat("MM1_To_PM1_presence",1,1)
findstr(b_net,"\005F\" )=mat(4,7,11,3,1)
b_net:strrep(b_net,"\005F\","\005F\" )="MM1\005F\To\005F\PM1\005F\presence"
strsplit(b_net,"\005F\" )=mat("MM1","To","PM1","presence",4,1)
I have this trouble since the lasted stable version.
With the previous stable version, 0.99 build 7610, the split function is ok :
strsplit(b_net,"_" )=mat("MM1","To","PM1","presence",4,1)
Please to not take into consideration the space before the parenthesis.
If not, there is a smiley "Wink.
Thanks
Bricemik
#4 Posted : 02 June 2021 19:55:57(UTC)
Please could you attach your worksheet? I cannot reproduce this issue.
Offline bricemik
#5 Posted : 02 June 2021 21:33:26(UTC)
bricemik
France
Please find attached the files.
test_strsplit_input.txt (1kb) downloaded 10 time(s). test_strsplit.sm (9kb) downloaded 11 time(s).
thanks 1 user thanked bricemik for this useful post.
on 02/06/2021(UTC)
#6 Posted : 02 June 2021 22:29:26(UTC)
Thank you! Reproduced.
Will fix.
Offline overlord
#7 Posted : 02 June 2021 22:32:06(UTC)
Turkey
Will fix.
Maybe windows release has this issue.
Linux load and split it correctly.
