Offline takez
#1 Posted : 28 May 2021 16:21:06(UTC)
takez
Japan
hi,
I'm a beginner
I get an error in the calculation
error :
result is above max. Allowed positive number
How can I solve it?
impedance.sm (35kb) downloaded 10 time(s).
Offline overlord
#2 Posted : 28 May 2021 16:39:29(UTC)
Turkey
Originally Posted by: takez Go to Quoted Post
hi,
I'm a beginner
error :
How can I solve it?
Change your calculation result from symbolic to numeric.
You can do it with eval() since they are all numbers.
Offline takez
#3 Posted : 28 May 2021 21:27:57(UTC)
takez
Japan
Thank you
I understand the cause of the error
#4 Posted : 29 May 2021 00:40:26(UTC)
eval() is a general rule but an absolute rule.
Many projects fail from eval(,).
SS 6179 does not complain as you constructed.
eval(,) is applied afterwards to isolate/accelerate.
#5 Posted : 29 May 2021 02:33:21(UTC)
Good application case to globalize within the program.
... in my SS 6179 timing drops from 2.6 s down to 1.6 s
Offline takez
#6 Posted : 29 May 2021 02:55:57(UTC)
takez
Japan
Thank you.
I was able to calculate the frequency characteristics
(PP2.sm)
But when I modify a circuit, I get an error even with eval.
(PPS.sm)
it's very difficult.
PPS.sm (177kb) downloaded 9 time(s).
PP2.sm (168kb) downloaded 7 time(s).
#7 Posted : 29 May 2021 16:50:48(UTC)
Thank you.
(PP2.sm)
(PPS.sm)
... sorry, can't help: this document opens freak SS 6179.
You seem to put too much that can't be debugged piece wise.
Offline Razonar
#8 Posted : 29 May 2021 18:11:55(UTC)
Razonar
Uruguay
Thank you.
(PP2.sm)
(PPS.sm)
Hi Takez. Yes, it's very difficult recognize or even guess where the program needs some evals. Also, putting them everywhere make unreadable the procedures. In the case of your PPS.sm that's SMath stores into Z without eval
and this with it
So, for PPS.sm there is where you need to use eval, and seems that then all other calculations works.
Offline overlord
#9 Posted : 29 May 2021 18:33:20(UTC)
Turkey
Razonar's is the correct solution.
Deleting my post.
on 29/05/2021(UTC)
Similar Topics
Ignore units or Error: Result is above max.allowed positive number (Bugs & Problems)
by radex 15/12/2015 22:19:07(UTC)
Error: Result is above max allowed positive number (Bugs & Problems)
by datsnl 15/05/2013 08:30:46(UTC)
