SMath Studio Forum
Bugs & Problems
Error in element-wise calculation with nested functions
Joined: 23/07/2019(UTC) Posts: 7 Location: Saarbrücken
Hello, the (very smart) element-wise calculation seems to be buggy if applied to nested functions. The result can be calculated correctly, but cannot be assigned to a new variable. I found this issue in a complex calculation and simplified it to the attached problem: - A first function uses an if-statement to calculate the result - A second funtion calls the first function and multiplies the result with "1" If either the if-statement or the multiplication is removed, everything works fine. This seems to be strange... Used SMath-version: 0.99.7610, but also with current Beta-version 0.99.7804 For own tests: TestElem.sm (12kb) downloaded 3 time(s).
Joined: 15/07/2010(UTC) Posts: 437 Location: Beer-Sheva Was thanked: 520 time(s) in 288 post(s)
Use the function eval() eval.sm (12kb) downloaded 16 time(s).
Seems to work! Thank you for your fast response!
SMath Studio Forum
Bugs & Problems
