Offline ndtma
#1 Posted : 27 February 2021 18:48:24(UTC)
ndtma
Sri Lanka
Was thanked: 96 time(s) in 66 post(s)
A simple example involving a pipe network having 2 loops.
To demonstrate how Hardy-Cross method is applied to find the flow in individual pipe of the network.
Three methods used to illustrate. May be suitable for beginners.
However, this solution can be easily obtained using 'FindRoot' method also, but is not shown in the example.
Cheers.
Pipe_Network_EX_HARDY_CROSS.sm (288kb) downloaded 149 time(s).
Pipe_Network_EX_HARDY_CROSS.pdf (1,021kb) downloaded 236 time(s).
thanks 1 user thanked ndtma for this useful post.
on 27/02/2021(UTC)
Offline ndtma
#2 Posted : 16 March 2021 14:16:17(UTC)
ndtma
Sri Lanka
The earlier example was for 2 loops
Attached example is for 3 loops.
Hope will be useful.
Cheers!
Pipe_Network_EX_HARDY_CROSS_3 LOOPS.sm (551kb) downloaded 51 time(s).
Pipe_Network_EX_HARDY_CROSS_3 LOOPS-compressed.pdf (648kb) downloaded 73 time(s).
#3 Posted : 16 March 2021 18:19:51(UTC)
Was thanked: 852 time(s) in 682 post(s)
Thanks for that exceptional work, saved in my Instrumentation compendium.
Take care ... Jean
Offline ElSid
#4 Posted : 16 March 2021 18:22:24(UTC)
ElSid
Was thanked: 15 time(s) in 13 post(s)
ndtma
Not sure is you can combine this with your previous post from 5 years ago https://en.smath.com/for...pe-Network-Analysis.aspx
That one was one loop, this one has 2 and 3 loops Good
Offline ndtma
#5 Posted : 18 March 2021 05:23:33(UTC)
ndtma
Sri Lanka
Take care ... Jean
Thank you Jean for your kind words and encouragement.
Take care.
Offline CBG
#6 Posted : 18 March 2021 20:59:16(UTC)
CBG
Was thanked: 64 time(s) in 47 post(s)
Hello ndtma
I have used Epanet to solve your exercise, by the Hazen Williams method with the following assumptions:
Minimum tank height 66 meters
the roughness of the pipe 120
node height 0 meters
diameter in millimeters
pipe length in meters
Carlos
Offline ndtma
#7 Posted : 19 March 2021 06:54:06(UTC)
ndtma
Sri Lanka
Thank you Carlos.
Offline ndtma
#8 Posted : 26 March 2021 08:49:39(UTC)
ndtma
Sri Lanka
I am extremely sorry that in my last example on 3 LOOPS, I have made a careless mistake in Program 2 to calculate the appropriate corrections in the network. The results were wrong.
Furthermore, for simplicity, I assumed a fixed friction factor instead of the method given in the original EXCEL file in the web.
The revised SM and EXCEL files are attached. They both tally. The original EXCEL file had only 5 trials and I extended to 10 trials.
Also, many thanks to Carlos for his example using EPANET which prompted me to check and correct my program.
Pipe_Network_EX_HARDY_CROSS_3 LOOPS-R2.sm (262kb) downloaded 37 time(s).
Pipe_Network_EX_HARDY_CROSS_3 LOOPS-R2-compressed.pdf (470kb) downloaded 38 time(s).
hardy cross_3 LOOPS_R2.xlsx (764kb) downloaded 30 time(s).
Edited by user 26 March 2021 09:24:47(UTC)  | Reason: Not specified
Offline ndtma
#9 Posted : 18 April 2021 16:06:09(UTC)
ndtma
Sri Lanka
Hardy Cross method revisited.
The friction factor for turbulent flow is calculated using the Colebrook-White equation.
Due to the implicit nature of this equation, calculation of the friction factor requires an iterative solution via numerical methods. Hence, many explicit approximations have been proposed such as Haaland, Moody, Jain etc. to simplify the calculation process.
The attached sm file shows the iterative method of solving the Colebrook-White equation to calculate ONLY the friction factor ‘f’, for use in the Hardy Cross method. The calculated pipe flows were well within the values obtained in my last example.
Cheers.
Colebrook-White-Numerical Soltion.sm (45kb) downloaded 27 time(s).
Colebrook-White-Numerical Soltion.pdf (177kb) downloaded 20 time(s).
Edited by user 18 April 2021 16:13:59(UTC)  | Reason: Not specified
on 18/04/2021(UTC)
#10 Posted : 18 April 2021 18:28:52(UTC)
Thanks for sharing the improved project method.
Take care ... Jean
Offline NotRetiredYet
#11 Posted : 20 April 2021 02:33:49(UTC)
NotRetiredYet
ndtma...
This is very fine work indeed and much better than doing Hardy-Cross by hand like I had to do a few times in college back in the late 1970s. That 4-loop Hardy-Cross model I had to solve was almost enough to make me want to become a lawyer. Almost. :-) However, I now use EPANET and WATERCAD for my modeling needs and life is good. I also use Hazen-Williams far more often than Darcy-Weisbach/Colebrook-White and life is even better.
You mention above explicit approximations to Colebrook-White. This is a topic that has interested me since I learned of the Blasius Equation in college. Blasius does a decent job approximating the smooth pipe curve on the Moody Diagram, but only over a limited range of Reynolds Numbers. Over the years, I have run across at least two dozen published explicit approximations to CW. I even created my own improvement to Blasius, although it pales in comparison to some of the others.
Back in 2014, I published on the PTC website two Mathcad Prime 3.0 worksheets that evaluated these explicit approximations for accuracy and relative calculation speed. For accuracy, I used CW as the basis, even though it is itself empirical and includes an empirical friction factor. Computers are so fast now that relative calculation speed is not as relevant as it was when I started my career in 1980. However, it matters for calculator programs. I used an HP-41CX and it's built in time functions to measure and compare calculation speeds.
One MCP worksheet is for hydraulically smooth pipe (the equations simplify) and the other is for hydraulically rough pipe (the usual case). Y'all can find these worksheets here: https://community.ptc.co...actors-v2-zip/m-p/450068 . Don't worry if you don't have Mathcad Prime 3.0 or later. The .zip file contains Acrobat .pdf files for your reading pleasure. And, please excuse the funky page formatting near the end of each worksheet. These are big files and I had pushed MCP3 to its limits.
Fred
Edited by user 24 April 2021 00:44:55(UTC)  | Reason: Not specified
Offline ndtma
#12 Posted : 20 April 2021 08:38:10(UTC)
ndtma
Sri Lanka
Thank you. Your explanation is welcome.
I don't have any experience in EPANET and WATERCAD.
My aim was to demonstrate basics of Hardy Cross method using SMath and and the importance of
the Vectorize function when dealing with nested matrices.
Stay safe. Take care.
Cheers.
#13 Posted : 21 April 2021 01:59:22(UTC)
In my Engineering times, before 1990, the Bible was Moody from standards.
There is nothing to explicit CW, it solves on the running Reynolds,
and for a family of diameters, just like in the Bible diagram.
Smath attached is 1/1 Mathcad 8 Pro [2000].
Inst_Colebrook MOODY.sm (17kb) downloaded 32 time(s).
Offline Valentino
#14 Posted : 15 September 2021 04:28:04(UTC)
Valentino
Rank: Member
Mexico
Was thanked: 7 time(s) in 3 post(s)
Hello, I am very happy to read your publication, thank you for generating these documents. I want to download your files, however, they do not allow me access, please upload them again. Thank you very much, greetings from Mexico.
#15 Posted : 15 September 2021 15:33:59(UTC)
Was thanked: 1201 time(s) in 792 post(s)
Just click the links you quoted. Attached files are hosted within this website, so there's no expiration. Also check if there is some policy that restrict downloads on your system.
Offline ndtma
#16 Posted : 15 September 2021 18:13:37(UTC)
ndtma
Sri Lanka
Hello Valentino,
Were you able to download the files in my post as suggested by Davide?
I am sorry for the late reply.
