Offline netsonicyxf
#1 Posted : 30 January 2021 12:24:43(UTC)
netsonicyxf
  1. There is no replace option.
  2. I suggest use muti-level-criteria for find and replace selection:
    The first level is
    whole document / from mouse point above / from mouse point below /select regions
    The second level is
    all / text / math
    The third level applies to math only
    all / variable only / subscripts only / superscripts only
Edited by user 30 January 2021 12:31:23(UTC)  | Reason: Not specified
#2 Posted : 30 January 2021 15:50:03(UTC)
Replace what, where by what ?
In math regions we have:
click the var/parameter, F8, back space, new.
Offline ElSid
#3 Posted : 30 January 2021 16:57:12(UTC)
ElSid
I can see uses, especially with the NEW document mode. Andrey even improved the search feature in 0.99.7691 BETA.
Offline netsonicyxf
#4 Posted : 30 January 2021 17:26:56(UTC)
netsonicyxf
I tried it, it has some limits
  1. it works for variable only, but it doesn't work for super/sub-script.
  2. it only work in one region for one time, it not work for multiple regions or the whole document.
  3. it doesn't work for text regions.
Edited by user 30 January 2021 17:29:47(UTC)  | Reason: Not specified
#5 Posted : 30 January 2021 21:38:42(UTC)
  • it works for variable only, but it doesn't work for super/sub-script.
  • it only work in one region for one time, it not work for multiple regions or the whole document.
  • it doesn't work for text regions.
  • 1. It works for parameters as well.
    2. Works for interlated regions, as multiple times.
    3. Zap part of text, paste or compose new stuff.
