Good evening, Looking for suggestions to better improve the maths. I am working on the write up on the side on another Sheet. I'm having an issue in when it comes to eliminating units, better yet, proving units cancel out. Suggestions on how to better derive and show the process is appreciated. HVAC Constants.sm (56kb) downloaded 20 time(s).
1 user thanked ElSid for this useful post.
Originally Posted by: ElSid Good evening, Looking for suggestions to better improve the maths. I am working on the write up on the side on another Sheet. I'm having an issue in when it comes to eliminating units, better yet, proving units cancel out. Suggestions on how to better derive and show the process is appreciated. HVAC Constants.sm (56kb) downloaded 20 time(s). Hi. SMath convert all numbers to it rational approximation in symbolic outputs. Maybe you can use this trick: put Q*ΔT in units and use numeric evaluation: Best regards. Alvaro.
Originally Posted by: Razonar Hi. SMath convert all numbers to it rational approximation in symbolic outputs. Maybe you can use this trick: put Q*ΔT in units and use numeric evaluation
Best regards. Alvaro. Help with the highlighted please. How do I put the variables into Units? File is updated on my laptop to numeric evaluation.
The error message reads yellow not defined
Originally Posted by: Jean Giraud The error message reads yellow not defined And ALVARO had a way around it where his SNIPPET/PICTURE shows what I want
Originally Posted by: ElSid Help with the highlighted please. How do I put the variables into Units? File is updated on my laptop to numeric evaluation. HVAC Constants.sm (63kb) downloaded 8 time(s).Hi. Just write them: " Q*ΔT*'BTU/'hr " in the unit's placeholder. I attach the file too. Best regards. Alvaro. Edited by user 10 February 2021 21:10:48(UTC)
| Reason: Not specified
on 10/02/2021(UTC), on 10/02/2021(UTC)
Originally Posted by: Razonar Hi. Just write them: " Q*ΔT*'BTU/'hr " in the unit's placeholder. Best regards. Alvaro. Got it. You force the solution (=) side to keep Q and ΔT as variables. I think I tried everything BUT that! Revised file HVAC Constants.sm (63kb) downloaded 6 time(s).Edited by user 10 February 2021 22:39:56(UTC)
| Reason: Uploaded the file
