Offline EngMath
#1 Posted : 18 October 2020 23:44:45(UTC)
EngMath
Rank: Member
Poland
I've just started using this software and I think that it's great. However, I came across an issue that may be a bug. Here's my input:
a := 0,1 m
b := 0,05 m
L := 1 m
M := 1000 Nm
τ_max := (2*M)/(π*a*(b^2)) =
Now in the last line I want to change units to MPa. But when I do it (by writing MPa in the right placeholder), I get the following result:
No matter what I try, I can't get rid of this part that I highlighted in red. I want to have just MPa on the right side. Is that a bug or am I doing something wrong ?
Online overlord
#2 Posted : 18 October 2020 23:54:25(UTC)
Turkey
Was thanked: 59 time(s) in 42 post(s)
Nothing is wrong.
Could you please check your expressions carefully?
#3 Posted : 18 October 2020 23:59:32(UTC)
Was thanked: 1167 time(s) in 768 post(s)
Perhaps you are using 'Nm instead of 'N*'m
If you want you can define your own torque unit 'Nm:'N*'m before the calculations, otherwise you have to multiply the force unit fot the length unit
Edited by user 19 October 2020 10:32:03(UTC)  | Reason: marked as solved
Offline EngMath
#4 Posted : 19 October 2020 00:02:47(UTC)
EngMath
Rank: Member
Poland
Problem solved, thank you very much. I had to type 'N*'m as you say because 'Nm wasn't recognized properly.
Offline Int16
#5 Posted : 10 November 2020 14:35:58(UTC)
Int16
How to compute this
Offline PompelmoTell
#6 Posted : 10 November 2020 18:20:49(UTC)
PompelmoTell
Was thanked: 81 time(s) in 68 post(s)
The problem is due to the internal storage of the program in Kelvin. You find several threads in the forum. you can also find an explanation in Martin Kraska's interactive guide (Tools menu -> Options -> Plugins -> interactive books). However the solution is to use DeltaC °
on 12/11/2020(UTC)
Offline Int16
#7 Posted : 12 November 2020 15:04:06(UTC)
Int16
Thanks a lot.
#8 Posted : 12 November 2020 16:30:53(UTC)
Was thanked: 809 time(s) in 642 post(s)
... you can make the unit system silent, i.e: inactive
Offline mkraska
#9 Posted : 13 November 2020 23:55:49(UTC)
mkraska
Was thanked: 915 time(s) in 575 post(s)
This is close to recommending pencil and paper.
#10 Posted : 14 November 2020 14:49:14(UTC)
Pretty close Martin, that's ± what QA sanity check does.
The mV/I temperature converter reads mV ... then displays °C.
In parallel to the black box mV/I, read mV, interpolate wrt NBS [now NIST].
#11 Posted : 14 November 2020 20:24:48(UTC)
wrong display of output units
You will have infinitely many of those, easy to doctor:
1. make the system silent, though not quite paper/pencil
2. make it user style at will.
