Offline ianlh
#1 Posted : 18 July 2020 15:08:11(UTC)
ianlh
Rank: Member
Hi All,
Trying to work out a universal way of getting the length of intersecting lines, easy when lines are level, but not so (for me) others.
The image below shows a lifting lug, the angle of action can be 0 deg to 150 deg for example. I need to know the length of the lines from the red circle to the outline, individually, then I can see the shortest length, this must be for all angles, effectively tracing the intersection point through the angles. I know I can use Pythagoras, but was hoping to use something like GPC, but this works only for polygons?
Lug Horizontal.sm (27kb) downloaded 12 time(s).
Offline Ber7
#2 Posted : 18 July 2020 19:42:58(UTC)
Ber7
Israel
Was thanked: 486 time(s) in 266 post(s)
Try a short circle code.
thanks 1 user thanked Ber7 for this useful post.
on 18/07/2020(UTC)
Online Jean Giraud
#3 Posted : 19 July 2020 01:09:52(UTC)
Was thanked: 842 time(s) in 672 post(s)
Anything helpful in there ?
Solve Circle Ellipse Strophoid NASA.sm (239kb) downloaded 19 time(s).
Offline ianlh
#4 Posted : 19 July 2020 12:39:06(UTC)
ianlh
Rank: Member
Hi Jean,
I will have a look, I'm sure I can use something.
Thanks
Offline Ber7
#5 Posted : 20 July 2020 11:24:38(UTC)
Ber7
Israel
ianlh, in your example it’s convenient to use the rotation matrix
Lug Horizontal1.sm (19kb) downloaded 16 time(s).
on 21/07/2020(UTC)
Online Jean Giraud
#6 Posted : 20 July 2020 14:34:13(UTC)
Whereas the system is built scalar wrt θ
make it more convenient local at graph display.
Lug Horizontal_2.sm (23kb) downloaded 12 time(s).
Offline mkraska
#7 Posted : 20 July 2020 19:46:20(UTC)
mkraska
Was thanked: 919 time(s) in 578 post(s)
This provides the shortest distance from the segments of the polygon to the circle. However, the distance isn't really to the segment but to a line through the endpoints of the segment. There is no test if the normal to the line through c is between the vertices of the segment.
For the given geometry this works. For proof of strength this is only useful if a given force may act under any angle but the force doesn't depend on that angle.
Lug Horizontal_Kr.sm (32kb) downloaded 11 time(s).
on 20/07/2020(UTC),  on 21/07/2020(UTC)
Offline Razonar
#8 Posted : 21 July 2020 08:25:44(UTC)
Razonar
Uruguay
Was thanked: 370 time(s) in 245 post(s)
Originally Posted by: ianlh Go to Quoted Post
Hi All,
Hi. Your request it's about a complex computer graphic problem. This is a page for an undergraduated course: https://www.fing.edu.uy/inco/cursos/compgraf/
This paper have a pseudo code for solve partially your problem:
http://www.itseng.org/re...roblems/1979-Bentley.pdf
Hope that's helps.
on 21/07/2020(UTC)
Offline Razonar
#9 Posted : 21 July 2020 08:44:11(UTC)
Razonar
Uruguay
Hi. This is what's actually do the Ber'f function:
But notice that for use matrix multiplication for translations you must to use homogeneous coords ( http://elopez.fime.uanl.mx/@materias/732/@Tema%203%20-%20Transformaciones%202D.pdf page 15)
on 21/07/2020(UTC),  on 21/07/2020(UTC)
Offline Ber7
#10 Posted : 21 July 2020 13:37:50(UTC)
Ber7
Israel
Thank you, Razonar.Aapplying homogeneous coordinates helps automate the process.
Variant with homogeneous coordinates
Lug Horizontal3.sm (18kb) downloaded 12 time(s).
Edited by user 21 July 2020 14:37:24(UTC)  | Reason: Not specified
thanks 2 users thanked Ber7 for this useful post.
Offline Razonar
#11 Posted : 21 July 2020 20:15:57(UTC)
Razonar
Uruguay
Variant with homogeneous coordinates ...
Another variant.
Lug Horizontal4.sm (35kb) downloaded 12 time(s).
Homogeneous coordinates are helpful in projective geometry and conics and quadrics. For instance, preserve the duality, because you can use line coordinates ( https://en.wikipedia.org/wiki/Line_coordinates ).
I try to modify for use that in https://en.smath.com/for..._postst17357_Conics.aspx but can't found a close end. This is my atemp for the dual of a conic, it's envelope:
on 21/07/2020(UTC),  on 22/07/2020(UTC)
Offline Ber7
#12 Posted : 24 July 2020 15:27:21(UTC)
Ber7
Israel
Rotate around an arbitrary axis in space
3d rotate.sm (22kb) downloaded 17 time(s).
on 24/07/2020(UTC),  on 25/07/2020(UTC)
Offline Razonar
#13 Posted : 27 July 2020 06:37:33(UTC)
Razonar
Uruguay
Hi Ber. That's not science, that's art. Maybe you can find this book interesting: Modern Robotics.
At page 608 in the pdf, for example:
The notation isn't the best, but it can be converted to a general Rotations and translations for the forward kinematics of a robot.
on 27/07/2020(UTC),  on 27/07/2020(UTC)
Offline Ber7
#14 Posted : 27 July 2020 11:31:15(UTC)
Ber7
Israel
Hello Razonar. "Modern Robotics" book
sparked my big interest. Thank you for the link.
