Offline ianlh
#1 Posted : 18 July 2020 15:08:11(UTC)
ianlh
Rank: Member
Hi All,
Trying to work out a universal way of getting the length of intersecting lines, easy when lines are level, but not so (for me) others.
The image below shows a lifting lug, the angle of action can be 0 deg to 150 deg for example. I need to know the length of the lines from the red circle to the outline, individually, then I can see the shortest length, this must be for all angles, effectively tracing the intersection point through the angles. I know I can use Pythagoras, but was hoping to use something like GPC, but this works only for polygons?
Lug Horizontal.sm (27kb) downloaded 8 time(s).
Offline Ber7
#2 Posted : 18 July 2020 19:42:58(UTC)
Ber7
Israel
Was thanked: 453 time(s) in 244 post(s)
Try a short circle code.
thanks 1 user thanked Ber7 for this useful post.
on 18/07/2020(UTC)
#3 Posted : 19 July 2020 01:09:52(UTC)
Was thanked: 792 time(s) in 628 post(s)
Anything helpful in there ?
Solve Circle Ellipse Strophoid NASA.sm (239kb) downloaded 13 time(s).
Offline ianlh
#4 Posted : 19 July 2020 12:39:06(UTC)
ianlh
Rank: Member
Hi Jean,
I will have a look, I'm sure I can use something.
Thanks
Offline Ber7
#5 Posted : 20 July 2020 11:24:38(UTC)
Ber7
Israel
ianlh, in your example it’s convenient to use the rotation matrix
Lug Horizontal1.sm (19kb) downloaded 12 time(s).
on 21/07/2020(UTC)
#6 Posted : 20 July 2020 14:34:13(UTC)
Whereas the system is built scalar wrt θ
make it more convenient local at graph display.
Lug Horizontal_2.sm (23kb) downloaded 7 time(s).
Offline mkraska
#7 Posted : 20 July 2020 19:46:20(UTC)
mkraska
Was thanked: 869 time(s) in 552 post(s)
This provides the shortest distance from the segments of the polygon to the circle. However, the distance isn't really to the segment but to a line through the endpoints of the segment. There is no test if the normal to the line through c is between the vertices of the segment.
For the given geometry this works. For proof of strength this is only useful if a given force may act under any angle but the force doesn't depend on that angle.
Lug Horizontal_Kr.sm (32kb) downloaded 7 time(s).
on 20/07/2020(UTC),  on 21/07/2020(UTC)
Offline Razonar
#8 Posted : 21 July 2020 08:25:44(UTC)
Razonar
Uruguay
Was thanked: 292 time(s) in 181 post(s)
Originally Posted by: ianlh Go to Quoted Post
Hi All,
Hi. Your request it's about a complex computer graphic problem. This is a page for an undergraduated course: https://www.fing.edu.uy/inco/cursos/compgraf/
This paper have a pseudo code for solve partially your problem:
http://www.itseng.org/re...roblems/1979-Bentley.pdf
Hope that's helps.
on 21/07/2020(UTC)
Offline Razonar
#9 Posted : 21 July 2020 08:44:11(UTC)
Razonar
Uruguay
Hi. This is what's actually do the Ber'f function:
But notice that for use matrix multiplication for translations you must to use homogeneous coords ( http://elopez.fime.uanl.mx/@materias/732/@Tema%203%20-%20Transformaciones%202D.pdf page 15)
on 21/07/2020(UTC),  on 21/07/2020(UTC)
Offline Ber7
#10 Posted : 21 July 2020 13:37:50(UTC)
Ber7
Israel
Thank you, Razonar.Aapplying homogeneous coordinates helps automate the process.
Variant with homogeneous coordinates
Lug Horizontal3.sm (18kb) downloaded 7 time(s).
Edited by user 21 July 2020 14:37:24(UTC)  | Reason: Not specified
thanks 2 users thanked Ber7 for this useful post.
Offline Razonar
#11 Posted : 21 July 2020 20:15:57(UTC)
Razonar
Uruguay
Variant with homogeneous coordinates ...
Another variant.
Lug Horizontal4.sm (35kb) downloaded 6 time(s).
Homogeneous coordinates are helpful in projective geometry and conics and quadrics. For instance, preserve the duality, because you can use line coordinates ( https://en.wikipedia.org/wiki/Line_coordinates ).
I try to modify for use that in https://en.smath.com/for..._postst17357_Conics.aspx but can't found a close end. This is my atemp for the dual of a conic, it's envelope:
on 21/07/2020(UTC),  on 22/07/2020(UTC)
Offline Ber7
#12 Posted : 24 July 2020 15:27:21(UTC)
Ber7
Israel
Rotate around an arbitrary axis in space
3d rotate.sm (22kb) downloaded 11 time(s).
on 24/07/2020(UTC),  on 25/07/2020(UTC)
Offline Razonar
#13 Posted : 27 July 2020 06:37:33(UTC)
Razonar
Uruguay
Hi Ber. That's not science, that's art. Maybe you can find this book interesting: Modern Robotics.
At page 608 in the pdf, for example:
The notation isn't the best, but it can be converted to a general Rotations and translations for the forward kinematics of a robot.
on 27/07/2020(UTC),  on 27/07/2020(UTC)
Offline Ber7
#14 Posted : 27 July 2020 11:31:15(UTC)
Ber7
Israel
Hello Razonar. "Modern Robotics" book
sparked my big interest. Thank you for the link.
