SMath Studio Forum
Bugs & Problems
SMATH Error - Won't Load Existing XMCD File (Build 0.96.4868)
Greetings. Have enjoyed using this as a successor to the commercial product which it seems to work like. I created a sheet in the XMCD format earlier, and now it is unable to open in the new version. Following is the information in the error dialogue that comes <FileName>.XMCD Could not load file or assembly 'TextRegion, Version=1.9.4868.42191, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified. The program does load, and is able to create a NEW sheet; as far as I can tell it works all right, just simply cannot load the existing .XMCD format file. Illbay attached the following image(s):
Fixed. Will be available in the next version.
Joined: 04/01/2012(UTC) Posts: 3 Location: Buenos Aires Was thanked: 1 time(s) in 1 post(s)
Andrey, this is an amazing job you have done with this program! I have a problem when I start SMath: apparently it can not load a group of plugin because it can't find the file 'mcaduser, version= 1.04614.654'. I don't konw it this problem is mine or a bug. Thank you. RASG attached the following image(s):
Originally Posted by: RASG Andrey, this is an amazing job you have done with this program! I have a problem when I start SMath: apparently it can not load a group of plugin because it can't find the file 'mcaduser, version= 1.04614.654'. I don't konw it this problem is mine or a bug. Thank you. This is my problem. Mathcad EFI plugin doesn't work in the new version. So, it must be removed. Remove two files: mcaduser.dll and mcadefi.dll. |
As I investigated situation with mcaduser caused by the same issue as described about XMCD. Issue already fix.
Uni, please, contact me via Skype - I'll give you latest internal build of SMath Studio to check how your plug-ins work.
Regards.
Abdrey: thank you for you interest in the problem. I really appreciate this amazing tool for my academic job (iI am teachenig numerical methods in college) an as civil engineer.
SMath Studio Forum
Bugs & Problems
