Joined: 02/02/2016(UTC) Posts: 35   Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: uni  Unfortunately, this cannot be done yet. Is there any other extension for smath that allows this?
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,314   Was thanked: 1147 time(s) in 662 post(s)
Joined: 04/07/2015(UTC) Posts: 6,097  Was thanked: 891 time(s) in 719 post(s)
Uni and Jean Giraud thank you very much!!!
ZedGraph Region made a logarithmic coordinate axis and build everything
Originally Posted by: veb  ZedGraph Region made a logarithmic coordinate axis and build everything Such applications are very limited, for convenience. IMHO, not much useful as we are born Cartesian sight.
Joined: 23/03/2016(UTC) Posts: 238  Was thanked: 76 time(s) in 47 post(s)
Originally Posted by: Jean Giraud  Originally Posted by: veb  ZedGraph Region made a logarithmic coordinate axis and build everything Such applications are very limited, for convenience. IMHO, not much useful as we are born Cartesian sight. I disagree. In electronics engineering we often deal in frequency domain with such applications as filter design, EMI/EMC, control.. just to name a few. Being able to plot on logarithmic scale is necessary in such applications. |
Originally Posted by: Jean Giraud  Such applications are very limited, for convenience. IMHO, not much useful as we are born Cartesian sight. A great utility is the logpts for convenient tabulation/export. Very useful to adequately populate the vertical region and not over populate the flat region, especially for interpolation. Utilities logpts Populate Quick.sm (15kb) downloaded 37 time(s).
Joined: 15/04/2012(UTC) Posts: 1,728  Was thanked: 950 time(s) in 602 post(s)
Originally Posted by: veb  Originally Posted by: uni  Unfortunately, this cannot be done yet. Is there any other extension for smath that allows this? The maxima plugin allows for log plots (all functions of the draw package are available, the draw commands generate images which can be displayed using image region. Alternatively, there are interactive draw regions provided by the plugin. See for example Ashby style material property charts
Joined: 28/08/2014(UTC) Posts: 983  Was thanked: 542 time(s) in 352 post(s)
Originally Posted by: mkraska  Originally Posted by: veb  Originally Posted by: uni  Unfortunately, this cannot be done yet. Is there any other extension for smath that allows this? The maxima plugin allows for log plots ... Hi. Can try this other one also, in SMath lang. examples MNA RLC.sm (220kb) downloaded 61 time(s). examples MNA RLC.pdf (319kb) downloaded 55 time(s).Best regards. Alvaro
Originally Posted by: Razonar  wow !!! When Uni told me that the X-U region does not support the logarithmic axis, I was upset and thought that I could do it in a standard tool. But I could not even imagine that it would be so difficult. ZedGraf region perfectly copes with the task, it is possible to make legends (have not yet learned). We rarely use charts in calculations.
Originally Posted by: veb  When Uni told me that the X-U region does not support the logarithmic axis, I was upset Disambiguate: Smath does not have the Cartesian x,y log axis from command line like Mathcad 11 and earlier. In lieu X_Y ZedGraph plugin. I guess Uni [our Viacheslav] is same from former Mathsoft Collaboratory.
Joined: 10/12/2009(UTC) Posts: 177   Location: Cali, Colombia Was thanked: 54 time(s) in 41 post(s)
 1 user thanked oscampo for this useful post.
Originally Posted by: oscampo  Thanks, I'll keep it in mind. But while the ZedGraph Region completely suits me.
Originally Posted by: veb  But while the ZedGraph Region completely suits me. What you can do in the linear Cartesian, you can subdivide between integer values of the quick plot. You can subdivide in any number of sub-intervals and log10 these sub-intervals. Then plot the stems at those intervals. Utilities logpts SQRT X,Y.sm (29kb) downloaded 38 time(s).
Pie chart with random colors  piechart.sm (10kb) downloaded 35 time(s). |
 4 users thanked mkraska for this useful post.
on 09/02/2020(UTC), on 09/02/2020(UTC), on 09/02/2020(UTC), on 09/02/2020(UTC)
Originally Posted by: mkraska  Pie chart with random colors Thanks Martin, interesting but not Smath native. Obviously fails SS 6179 and no use for concluding a document. Cheers ... Jean
Updated.
setprop() function changed for support ZedGraph region. |
on 22/04/2020(UTC), on 22/04/2020(UTC)
Joined: 12/02/2018(UTC) Posts: 55   Location: Belém Was thanked: 6 time(s) in 5 post(s)
Awesome!
I've just tested it and it fixes the Viewer issue I mentioned in another post.
Any chance it can access the configurations of indivual plots inside a ZedGraph Region? In other words, is it possible to address specific Traces?
It is possible, but not yet implemented. Also for the ZedGraph region the new Name property is not saved yet. |
Updated. Changes: - trace quality improved; - now default value for AntiAlias is true; - Y2 grid lines added; - setprop() function improved. Theoretically, we can set the dash style for implicit functions as well, but this is more difficult to implement.    Edited by user 10 May 2020 15:31:59(UTC)
on 10/05/2020(UTC), on 16/07/2020(UTC)
