SMath Studio Forum
Questions
Having trouble plotting data points
I am trying to plot some points in 2d space. Actually they are 2d points with values assigned to each point so it would be awesome if I could figure out how to plot 3d. When I click on the "Plot" buttons in smath nothing happens File attached. x, y, load.sm (7kb) downloaded 18 time(s).Thanks in advance!!!
Joined: 15/07/2010(UTC) Posts: 437 Location: Beer-Sheva Was thanked: 520 time(s) in 288 post(s)
The graph is easy to build in dimensionless coordinates. x, y, load1.sm (9kb) downloaded 28 time(s).Edited by user 20 March 2020 21:21:00(UTC)
| Reason: Not specified
Thank you Ber7, I will have to mess with this a bit more.
Originally Posted by: hunter_mike I will have to mess with this a bit more. View the graph of your data. x, y, load1 [graph].sm (15kb) downloaded 17 time(s).
Plotting data points On the Z axis we will display one tenth of the load 3d (3).sm (23kb) downloaded 13 time(s).Edited by user 21 March 2020 14:23:35(UTC)
Originally Posted by: hunter_mike I will have to mess with this a bit more. I guess so, up until now, you just have 3 vectors of data. The X, Y directions should produce a matrix. Here is a freak diagonal matrix. x, y, load1 [graph].sm (51kb) downloaded 10 time(s).
Essentially, your project does not describe what is what in there. Many missing links ...
... more from productive maths rhmsd= root harmonic mean square distance.. Maths [RHMSD unknown].sm (118kb) downloaded 13 time(s).
Originally Posted by: Jean Giraud ... more from productive maths rhmsd= root harmonic mean square distance.. ... check this version after removing the freak 17... point. Maths [RHMSD unknown].sm (118kb) downloaded 9 time(s).
SMath Studio Forum
Questions
