Offline roman111
#1 Posted : 01 February 2020 19:37:40(UTC)
roman111
Hello all. This is my case. It runs dramatically low. Can anyone give a hint for increasing speed? Or such a situation is normlal. Thanks. Postroenie polja riska.sm (149kb) downloaded 21 time(s).
Offline omorr
#2 Posted : 01 February 2020 20:27:20(UTC)
omorr
Groups: Registered, Administrators, Advanced Member
Serbia
Was thanked: 312 time(s) in 266 post(s)
Select all regions and put Optimization->Numeric
Offline roman111
#3 Posted : 01 February 2020 21:27:10(UTC)
roman111
Great! Fantastic! I was nearly diappointed, but it is really TOOL.
#4 Posted : 01 February 2020 23:33:30(UTC)
Was thanked: 751 time(s) in 592 post(s)
Much different stuff ... you can shift another set,
as well as plot in a random filled square.
Too long to resume in my laptop.
Circle Magic Disk.sm (28kb) downloaded 14 time(s).
Offline roman111
#5 Posted : 02 February 2020 20:33:18(UTC)
roman111
Thanks. It is better to use a file for data transfer. By now I don t engaged in working with plugins. One would like to try main concept. But later they will be strong required.
Offline ElSid
#6 Posted : 13 February 2020 01:26:04(UTC)
ElSid
Was thanked: 10 time(s) in 9 post(s)
You can always run SMath in a RamDisk (Significant speed improvement). I've started playing with this to speed up some computations, but most of my stuff is not plot intensive like the other Collabs. Just make sure you save your files to the disk or Poof, there goes your work
Offline roman111
#7 Posted : 14 February 2020 10:46:12(UTC)
roman111
Thank you very much. By the moment I have not tried yet but I just did not know about such a trick as RAM DISK.
Offline ElSid
#8 Posted : 14 February 2020 20:20:12(UTC)
ElSid
Ram Disk takes a portion of your RAM and "virtualizes" it into a drive. I'm using ImDisk which is free. Essentially, I've grabbed 4GB of my 16GB of ram and turned it into a virtual drive (in my case E:\). Once loaded, anything you put in there will now run at the speed of your ram. Gamers, Servers, dumps from databases, CAD, graphics intensive renderings (designers/3D virtualization) tend to use a variant of this. SDDs are fast enough for most, but this way there is no I/O to the disk. I also use this to compress/uncompress files. Just remember to save things before shutting down or *POOF* all gone. Essentially, I use use it as a scratch pad
NOTE: I will add that I'm on a laptop so I battery backup. If on a desktop, UPS is recomended
Offline PompelmoTell
#9 Posted : 14 February 2020 21:25:31(UTC)
PompelmoTell
Was thanked: 71 time(s) in 59 post(s)
ElSid,
​​I did not understand if in the RAMDisk you save (temporarily) only the .sm file or if you have to put for example a portable version of the SMath.
update 17/02/2020:
I tried to save the.sm file to a ramdisk, but I didn't measure any processing time benefit
Edited by user 17 February 2020 18:37:38(UTC)  | Reason: Not specified
#10 Posted : 17 February 2020 15:29:49(UTC)
... often in real Engineering works:
Discretize => transit to file.
