hi i have a table of values [R(t=60)=50965] with no obvious pattern and i need to create a function to fit into the formula 1/T = d (ln(R(t)) / dt my thought was to make S(t)=ln(R(t)) and do d(S(t))/dt but i dont know how to turn a bunch of values into a function in smath and excel doesnt understand the function properly (i left out the last value and did auto complete and it was too far off) R(t) is in counts per second and i am solving for T
Originally Posted by: Jean Giraud Originally Posted by: engineering student hi i have a table of values [R(t=60)=50965] with no obvious pattern and i need to create a function to fit into the formula 1/T = d (ln(R(t)) / dt Start by creating the Smath data table, attach in the Forum. Your wording looks very alike fitting the laser project. Toke > 1 month to do in Mathcad as it was so unusual. But we had lot more data points. Jean HW8Q1.sm (3kb) downloaded 13 time(s).do you mean like a matrix?
Originally Posted by: Jean Giraud Start by creating the Smath data table, Before going ahead, the wiggling around the straight fit, is it real or digitizing noise from equipment ?
Data.sm (29kb) downloaded 13 time(s).
Originally Posted by: Jean Giraud Originally Posted by: Jean Giraud Start by creating the Smath data table, Before going ahead, the wiggling around the straight fit, is it real or digitizing noise from equipment ? i would be comfortable assuming it is based on the context PNR HW 8 Fall 2019.pdf (309kb) downloaded 8 time(s).
... in your original scale XY. Data.sm (41kb) downloaded 13 time(s).
thank you so much as much as i would like to say part b of the question i need to do my own homework i just couldnt understand how to get the equation of that line
thanks again
Originally Posted by: engineering student thank you so much as much as I would like to say part b of the question I need to do my own homework I just couldn't understand how to get the equation of that line 1. You mean equation of the straight red line of the first plot ? 2. Or: the piece wise linterp between the support points ? linterp, cinterp, ainterp are built-in Smath from f(x) menu. The straight line in [1] can be manipulated a bit from statistical methods [Not Smath built-in]. Also, if you don't like the rough bifurcation at the supports points, easy to fillet for smooth path. No more need for the first replies before the last attachment, then will be removed. Cheers ... Jean
1 user thanked CBG for this useful post.
Here is Cholesky [Least Squares], otherwise. Ge sensor [Germanium] is an exceptional application. Jean Genfit 0 Ge SubCryogenic.sm (40kb) downloaded 16 time(s). Data.sm (55kb) downloaded 12 time(s).
