Joined: 02/02/2016(UTC) Posts: 35 Was thanked: 1 time(s) in 1 post(s)
Hello. Help me please! How to find the intersection of two matrices. Sorry if I said wrong. An example is attached, a graph is built in it. The graph shows that there are two intersections. How do I find the intersection coordinates. I have such a task. I need to get the third matrix, which begins as matrix (a), and after the intersection is constructed as matrix ( b ). Maybe someone knows the finished function. The matrices that we use in the problem always have two columns and a different number of rows. In the form of a matrix, we digitize graphs so that we can work with them. Question_Intersection.sm (39kb) downloaded 16 time(s).Edited by user 27 November 2019 18:15:21(UTC)
| Reason: Not specified
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
Originally Posted by: veb Help me please! How to find the intersection of two matrices. |
Originally Posted by: veb Help me please! How to find the intersection of two matrices. Sorry if I said wrong. An example is attached, a graph is built in it. The graph shows that there are two intersections. How do I find the intersection coordinates. I have such a task. I need to get the third matrix, which begins as matrix (a), and after the intersection is constructed as matrix ( b ). Maybe someone knows the finished function. The matrices that we use in the problem always have two columns and a different number of rows. In the form of a matrix, we digitize graphs so that we can work with them. As I read, the project is not of measuring the XY coordinates where a pile of planks do cross. The matrices that we use in the problem always have two columns and a different number of rows.The given example is from Mathsoft in the mathematical sense rather than Cartesian visual interpretation. You may read more from the web. While earth quake is shaking the barn, sooner or later and pair wise all cows will all collide. The linterp does your digitizing project. Cheers ... Jean Vector Maths [Intersection, Solve Coplanar].sm (96kb) downloaded 32 time(s).
PompelmoTell,This is just a great calculation. I never thought that finding intersection points was such a difficult task. I was preparing for something simple. Thank you so much, for I came up with my own method, which is many times simpler and only suits my types of graphs, when the construction goes from top to bottom, from left to right.
ndtma, Here I also expected such decision. When I saw him I really liked him. But for some reason, he didn’t want to work with my matrices.(
Jean Giraud, Sorry, I did not understand your calculation. The calculation is very complicated and at the end does not show the result
Originally Posted by: veb PompelmoTell,This is just a great calculation. I never thought that finding intersection points was such a difficult task. I was preparing for something simple. Thank you so much, for I came up with my own method, which is many times simpler and only suits my types of graphs, when the construction goes from top to bottom, from left to right.
ndtma, Here I also expected such decision. When I saw him I really liked him. But for some reason, he didnât want to work with my matrices.(
Jean Giraud, Sorry, I did not understand your calculation. The calculation is very complicated and at the end does not show the result 1. NDTMA is OK for what you gave. You didn't give any matrix. Is the matrix a surface plot ? To intersect with another surface plot or a plane or straight line, curved line 2. The attached is Marco's original ... looks like Pompelmo. Takes over 20 min in my box !!! 3. Forget my colliding points, surely not what you are looking for. If your matrix represent an Engineering surface of weird looking, we can spline/populate and intersect with a plane crossing. So, at this point: we are not yet in 1rst gear, no engine started. ... the matrix then what. Jean 3D Solid cut by Surface.sm (16kb) downloaded 24 time(s). Maths InterseX.sm (89kb) downloaded 26 time(s). Contour_8 Hypersurface.sm (1,192kb) downloaded 19 time(s).
