2 Pages<12
#21 Posted : 12 November 2019 21:38:42(UTC)
Was thanked: 792 time(s) in 628 post(s)
Offline ndtma
#22 Posted : 13 November 2019 13:59:29(UTC)
ndtma
Sri Lanka
Was thanked: 75 time(s) in 52 post(s)
Originally Posted by: ndtma Go to Quoted Post
Still I get errors in SS 7251.
After I got this error with 7251, again I did a Clean re-installation, and all issues posted later occurred consequent to this.
Furthermore, a similar Clean re-installation of 7251 was done in my second laptop today, but errors continued to occur with same test worksheets except Jean's "Test_Gamma_7251_[6179].sm".
Therefore, I have no alternative but leave it to the developers to decide.
Edited by user 13 November 2019 14:03:33(UTC)  | Reason: Not specified
#23 Posted : 13 November 2019 16:43:58(UTC)
Wait and see what Grand Doctors have to say.
Frechet PDF is another one that Simpson rejects.
In the attached, rescued in two ways.
When compatible, dn_GearsBDF is hyperfast, known accurate.
Thanks Collab for your contribution, most interesting.
Cheers ... jean
Integrate Frechet.sm (22kb) downloaded 12 time(s).
#24 Posted : 13 November 2019 18:01:37(UTC)
It carries parameters as well, following a fitting session.
Integrate Frechet.sm (29kb) downloaded 12 time(s).
Offline ndtma
#25 Posted : 15 November 2019 00:01:53(UTC)
ndtma
Sri Lanka
Observed same problems even after a second Clean re-installation of 7251.
Consequently, I noticed that the Vectorize operator works correctly
when eval() function is used to evaluate alpha and beta of the Gamma function.
Otherwise, it gives incompatible results.
Has anybody experienced this issue?
Thank you Jean for the inspiration and encouragement.
Thank you Alvaro.
Any comments?
New_Test_Gamma.sm (15kb) downloaded 13 time(s).
Edited by user 15 November 2019 00:17:56(UTC)  | Reason: Not specified
Offline Razonar
#26 Posted : 15 November 2019 01:23:02(UTC)
Razonar
Uruguay
Was thanked: 292 time(s) in 181 post(s)
Any comments?
New_Test_Gamma.sm (12kb) downloaded 8 time(s).
Hi Nugegodage. I slightly modify your file, putting eval only where Mean appear. What I see rigth now, with your new file using eval, not before, is that there are not bug, and the "bad results" are because Mean can't be vectorized (or better say, isn't a good idea vectorize them), like any other function that take vectors or matrices as arguments.
Edited by user 15 November 2019 01:41:51(UTC)  | Reason: Upload the smath file.
#27 Posted : 15 November 2019 03:08:16(UTC)
Not clear what's incompatible in the yellow/red brace.
Offline ndtma
#28 Posted : 12 May 2020 18:55:50(UTC)
ndtma
Sri Lanka
Gamma CDF function error revisited.
Following issues observed while trying to calculate SPI for a different set of data.
1. Gamma CDF function fails if 0 <'alpha' < 1
2. Even Razonar's method fails in such a situation.
3. According to the literature on calculation of SPI, the Gamma function is valid
for all 'alpha' values > 0.
4. No such issues in Excel or Mathcad.
5. Attached example is only to demonstrate the issue.
For the attention of authorities.
Gamma_CDF_Error_with_Alpha less than 1_.sm (14kb) downloaded 6 time(s).
Edited by user 12 May 2020 19:01:05(UTC)  | Reason: Not specified
thanks 1 user thanked ndtma for this useful post.
on 12/05/2020(UTC)
#29 Posted : 12 May 2020 22:02:58(UTC)
Your integration is ill posed ... "x_undefined"
SMath native Gamma(x) 4 decimals and INT acc 50 have no impact.
Try your own alpha/beta.
Page1 NDTMA.sm (14kb) downloaded 6 time(s).
on 13/05/2020(UTC)
Offline ndtma
#30 Posted : 13 May 2020 06:40:30(UTC)
ndtma
Sri Lanka
Thank you Jean. Your suggestion to introduce ε=10^{-15} as lower limit of integration
solved my problem. But still the error persists if lower limit is zero.
A beginner may be confused and/or discouraged in a similar situation.
Gamma_CDF_Error_with_Alpha less than 1_SOLVED.sm (107kb) downloaded 12 time(s).
Edited by user 13 May 2020 08:03:29(UTC)  | Reason: Not specified
on 14/05/2020(UTC)
#31 Posted : 14 May 2020 14:18:01(UTC)
Was thanked: 1153 time(s) in 757 post(s)
I see the issue... when alpha < 1 and t = 0 smath has 1/(0^(1-alpha)) and the numerical integrator fails. I'm not sure about how ccould be fixed.
Looking for improvements in the Gamma function...
Lanczos.sm (70kb) downloaded 12 time(s).
on 14/05/2020(UTC),  on 14/05/2020(UTC)
#32 Posted : 14 May 2020 22:22:08(UTC)
Thanks Davide: sanity check [real/complex] vs Keisan/Casio
#33 Posted : 14 May 2020 23:09:31(UTC)
All that is not as simple as the BigBang theory.
If the first computed 'x' appears in data < 10^-15
the quick plot rejects, no complain ... didn't check X_Y plot.
Thus: zero min value 10^-15.
Just experimented on Bézier/Bernstein project.
Offline ndtma
#34 Posted : 19 May 2020 11:49:32(UTC)
ndtma
Sri Lanka
A few more issues please.
Gamma_CDF_Error_Wrong_Results.sm (335kb) downloaded 7 time(s).
#35 Posted : 19 May 2020 14:26:46(UTC)
Freak 7251 does not open !
You just have two values: α:=0.7352, β:=245.7456
That's enough to simulate/evaluate CDF.
CDF Gamma.sm (263kb) downloaded 10 time(s).
Offline ndtma
#36 Posted : 20 May 2020 07:41:58(UTC)
ndtma
Sri Lanka
Sorry. PDF attached. Thank you Jean!
Gamma_CDF_Error_Wrong_Results.pdf (954kb) downloaded 6 time(s).
#37 Posted : 20 May 2020 16:46:24(UTC)
Ordinary Simpson is inadequate [too steep PDF, too long X's]
Romberg/Simpson algo style is just perfect.
All done in gray attached.
Cheers mon Ami from so far away !
CDF Gamma.sm (278kb) downloaded 9 time(s).
on 20/05/2020(UTC)
2 Pages<12
