This document is experimental, brute force in U.Given a function, we add white noise + bursts of outliers, then apply medsmoothEach new calculate work sheet generates different chirp. Cheers ... Jean Stat Outliers BruteForce Copy.sm (32kb) downloaded 25 time(s).
Originally Posted by: Jean Giraud This document is experimental, brute force in U.Given a function, we add white noise + bursts of outliers, then apply medsmoothEach new calculate work sheet generates different chirp. Cheers ... Jean Stat Outliers BruteForce Copy.sm (32kb) downloaded 25 time(s). It seems that Statistical Tools plugin needs corrections as well. Functions in it will not work with vectors anymore. Your file will work for SMath v. 7219 with these corrections Regards, Radovan |
Thanks Radovan for doctoring other versions. Refreshed ... note added. I was unable to finish the project as per Robert [Mathcad 11] There is another one of that kind. Cheers ... Jean Stat Outliers BruteForce.sm (63kb) downloaded 28 time(s).
