Offline tomtit
#1 Posted : 07 October 2019 19:03:02(UTC)
tomtit
Was thanked: 9 time(s) in 8 post(s)
Please see attached example.
sym_diff_issue.sm (4kb) downloaded 30 time(s).
#2 Posted : 08 October 2019 03:49:29(UTC)
Was thanked: 775 time(s) in 615 post(s)
What about completing the code to make it profitable ?
Not new the derivative of a constant is 0.
Offline Razonar
#3 Posted : 08 October 2019 04:07:31(UTC)
Razonar
Uruguay
Was thanked: 261 time(s) in 162 post(s)
Hi Tom. maple() knows how to eval diff because, as plugin, Viacheslav (uni, plugin author) know how to handle the function el(A,k). But notice what happen with an unknoun function, like El(A,k). So, problem here is what to do with the SMath el(A,k) with the operator diff.
on 08/10/2019(UTC)
#4 Posted : 08 October 2019 12:14:03(UTC)
Get more from the companions ...
#5 Posted : 08 October 2019 15:34:26(UTC)
As you mentioned Ei(x), like many special functions,
you may have to rescue from infinitesimal analysis,
the ancestor of CAS.
sym_diff_issue (more).sm (13kb) downloaded 13 time(s).
Offline tomtit
#6 Posted : 08 October 2019 17:35:59(UTC)
tomtit
I think this is a bug.
If there is no evidence that variable A[k] depends on x, dA[k]/dx should be immediately set to 0.
This is the way how symbolic engine of Wolfram Mathematica works.
Probably, I made a mistake mentioning "indexed functions", the right subject name should be "indexed symbolic variables" instead.
In real case A[k] were indexed unknowns in the system of equations.
I intentionally made this example as simple as possible to make it evident.
Edited by user 08 October 2019 17:38:45(UTC)  | Reason: Not specified
#7 Posted : 08 October 2019 21:52:05(UTC)
You can do lot more from lot less for real project:
1. get your function from index
2. get the partial derivatives wrt parameters in function.
sym_diff_issue (more).sm (24kb) downloaded 21 time(s).
