I do not think that the problem is only with the latest version of Smath; in the past I had problems with ome image file formats. Now the problem is presented for each format (svg, pdf, png ...).
Apparently the insertion procedure of an image works, but does not display any image; It is only a white box. If I try to save the file Smath you receive the following error.
If I try to run the "reset to original size" image from the context menu I get an error with the following exception:
Le informazioni su come richiamare il debug JIT (Just-In-Time) anziché questa finestra
sono riportate in fondo al messaggio.
************** Testo dell'eccezione **************
System.ArgumentException: Parametro non valido.
in System.Drawing.Bitmap..ctor(Int32 width, Int32 height, PixelFormat format)
in ImageEdit.ImageCanvas.LoadImage(String path_)
in ImageEdit.ImageRegion.PublicResize()
in ImageEdit.Main.<>c__DisplayClass5_0.<SMath.Controls.IPluginCustomRegion.GetContextMenuItems>b__3(MenuButtonArgs args)
in ..(Object , RegionBase , MenuButton )
in ...(Object , EventArgs )
in System.Windows.Forms.MenuItem.OnClick(EventArgs e)
in System.Windows.Forms.MenuItem.MenuItemData.Execute()
in System.Windows.Forms.Command.Invoke()
in System.Windows.Forms.Control.WmCommand(Message& m)
in System.Windows.Forms.Control.WndProc(Message& m)
in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Assembly caricati **************
mscorlib
Versione assembly: 4.0.0.0
Versione Win32: 4.8.3928.0 built by: NET48REL1
Base di codice: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
SMathStudio_Desktop
Versione assembly: 0.99.7201.17922
Versione Win32: 1.1.29.0
Base di codice: file:///C:/Program%20Files%20(x86)/SMath%20Studio/SMathStudio_Desktop.exe
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Versione Win32: 4.8.4001.0 built by: NET48REL1LAST_C
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Versione Win32: 4.8.3761.0 built by: NET48REL1
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
SMath.Manager
Versione assembly: 0.99.7201.17859
Versione Win32: 0.99.7201.17859
Base di codice: file:///C:/Program%20Files%20(x86)/SMath%20Studio/SMath.Manager.DLL
SMath.Environment
Base di codice: file:///C:/Program%20Files%20(x86)/SMath%20Studio/SMath.Environment.DLL
SMath.Drawing
Base di codice: file:///C:/Program%20Files%20(x86)/SMath%20Studio/SMath.Drawing.DLL
System.Configuration
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
SMath.Controls
Base di codice: file:///C:/Program%20Files%20(x86)/SMath%20Studio/SMath.Controls.DLL
SMath.Math.Symbolic
Versione assembly: 1.35.7201.17859
Versione Win32: 1.35.7201.17859
Base di codice: file:///C:/Program%20Files%20(x86)/SMath%20Studio/SMath.Math.Symbolic.DLL
SMath.Math.Numeric
Versione assembly: 1.67.7201.17859
Versione Win32: 1.67.7201.17859
Base di codice: file:///C:/Program%20Files%20(x86)/SMath%20Studio/SMath.Math.Numeric.DLL
SpecialFunctions
Versione assembly: 1.12.7201.17859
Versione Win32: 1.12.7201.17859
Base di codice: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/SpecialFunctions.dll
MathcadFileAccess
Versione assembly: 1.0.6983.32721
Versione Win32: 1.0.6983.32721
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/02a1c2c5-590e-46bb-bcf6-c87856a8b14b/1.0.6983.32721/MathcadFileAccess.dll
SliderRegion
Versione assembly: 1.0.7100.22009
Versione Win32: 1.0.7100.22009
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/0c864749-6fe8-4f62-a74d-f6ac601e52a5/1.0.7100.22009/SliderRegion.dll
SMath.UI
Versione assembly: 0.99.7201.17901
Versione Win32: 0.99.7201.17901
Base di codice: file:///C:/Program%20Files%20(x86)/SMath%20Studio/SMath.UI.DLL
CustomFunctions
Versione assembly: 1.1.7200.16172
Versione Win32: 1.1.7200.16172
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/18dadffd-79a3-4cf9-aee1-d66deb0ea720/1.1.7200.16172/CustomFunctions.dll
3DPlotRegion
Versione assembly: 0.1.7097.23130
Versione Win32: 0.1.7097.23130
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/2427d808-1e5e-4ae0-88bf-bc271664a3ab/0.1.7097.23130/3DPlotRegion.dll
CustomGlyphs
Versione assembly: 1.1.7200.16176
Versione Win32: 1.1.7200.16176
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/24c691c1-37f2-49e3-9a84-ccb77304d14a/1.1.7200.16176/CustomGlyphs.dll
ComboBoxRegion
Versione assembly: 0.1.7097.23243
Versione Win32: 0.1.7097.23243
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/28ea70bd-1dee-4200-b2e1-1d53d5832487/0.1.7097.23243/ComboBoxRegion.dll
DotNumerics
Versione assembly: 1.1.7166.24796
Versione Win32: 1.1.7166.24796
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/2a69099d-3185-4ea7-a130-65f2bf94c8d6/1.1.7166.24796/DotNumerics.dll
OSLO
Versione assembly: 0.1.6982.10165
Versione Win32: 0.1.6982.10165
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/2d031ecc-fa1f-4e70-81f4-16fcab80e32e/0.1.6982.10165/OSLO.dll
MapleTools
Versione assembly: 1.1.7162.25335
Versione Win32: 1.1.7162.25335
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/32dfd679-8cfd-483a-b79a-19d5ea838750/1.1.7162.25335/MapleTools.dll
ICSharpCode.SharpZipLib
Versione assembly: 0.86.0.518
Versione Win32: 0.86.0.518
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/32dfd679-8cfd-483a-b79a-19d5ea838750/1.1.7162.25335/ICSharpCode.SharpZipLib.DLL
Regions
Versione assembly: 0.1.7161.38686
Versione Win32: 0.1.7161.38686
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/32dfd679-8cfd-483a-b79a-19d5ea838750/1.1.7162.25335/Regions.DLL
IntelODESolverLibrary
Versione assembly: 0.1.7164.40868
Versione Win32: 0.1.7164.40868
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/37e523d9-65ab-43a1-8f3c-34868e181719/0.1.7164.40868/IntelODESolverLibrary.dll
Microsoft.CSharp
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.CSharp/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.CSharp.dll
iode64
Versione Win32:
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/37e523d9-65ab-43a1-8f3c-34868e181719/0.1.7164.40868/iode64.dll
System.Dynamic
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Dynamic/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Dynamic.dll
Anonymously Hosted DynamicMethods Assembly
Versione assembly: 0.0.0.0
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
NumericUpDownRegion
Versione assembly: 1.0.7100.21168
Versione Win32: 1.0.7100.21168
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/43438e49-5428-4036-8991-ce03b1d1e572/1.0.7100.21168/NumericUpDownRegion.dll
MaximaPlugin
Versione assembly: 1.98.7100.23756
Versione Win32: 1.98.7100.23756
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/44011c1e-5d0d-4533-8e68-e32b5badce41/1.98.7100.23756/MaximaPlugin.dll
SharpVectors.Rendering.Gdi
Versione assembly: 0.3.1.1595
Versione Win32: 0.3.1.1595
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/44011c1e-5d0d-4533-8e68-e32b5badce41/1.98.7100.23756/SharpVectors.Rendering.Gdi.DLL
SharpVectors.Core
Versione assembly: 0.3.1.1588
Versione Win32: 0.3.1.1588
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/44011c1e-5d0d-4533-8e68-e32b5badce41/1.98.7100.23756/SharpVectors.Core.DLL
SharpVectors.Model
Versione assembly: 0.3.1.1592
Versione Win32: 0.3.1.1592
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/44011c1e-5d0d-4533-8e68-e32b5badce41/1.98.7100.23756/SharpVectors.Model.DLL
SharpVectors.Css
Versione assembly: 0.3.1.1590
Versione Win32: 0.3.1.1590
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/44011c1e-5d0d-4533-8e68-e32b5badce41/1.98.7100.23756/SharpVectors.Css.DLL
SharpVectors.Dom
Versione assembly: 0.3.1.1589
Versione Win32: 0.3.1.1589
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/44011c1e-5d0d-4533-8e68-e32b5badce41/1.98.7100.23756/SharpVectors.Dom.DLL
HyperlinkRegion
Versione assembly: 1.0.7105.20106
Versione Win32: 1.0.7105.20106
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/4938d1a8-ad11-4de8-afbf-d76d069cfbf8/1.0.7105.20106/HyperlinkRegion.dll
TableRegion
Versione assembly: 0.2.7097.29803
Versione Win32: 0.2.7097.29803
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/51fec712-ec75-4551-a13e-478d375ae8d6/0.2.7097.29803/TableRegion.dll
WriterRegion
Versione assembly: 0.22.7200.15900
Versione Win32: 0.22.7200.15900
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/5922d677-323f-4327-8c68-be902d8339ad/0.22.7200.15900/WriterRegion.dll
NHunspell
Versione assembly: 1.2.5554.16953
Versione Win32: 1.2.5554.16953
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/5922d677-323f-4327-8c68-be902d8339ad/0.22.7200.15900/NHunspell.DLL
System.Web
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
Versione assembly: 1.0.6139.33115
Versione Win32: 1.0
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/5922d677-323f-4327-8c68-be902d8339ad/0.22.7200.15900/ICSharpCode.SharpZipLib.DLL
CheckBoxListRegion
Versione assembly: 1.0.7097.29767
Versione Win32: 1.0.7097.29767
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/5a6c4c4a-d9c3-4617-8179-b0b49297d8d4/1.0.7097.29767/CheckBoxListRegion.dll
DataExchange
Versione assembly: 1.1.6858.3747
Versione Win32: 1.1.6858.3747
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/5dce7298-9e5f-4120-9a2e-49b16daa02a3/1.1.6858.3747/DataExchange.dll
NonlinearSolvers
Versione assembly: 1.1.7097.23301
Versione Win32: 1.1.7097.23301
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/618b7e96-330a-406a-b055-9e577672f0b8/1.1.7097.23301/NonlinearSolvers.dll
XlsxImportExport
Versione assembly: 1.3.6996.39330
Versione Win32: 1.3.6996.39330
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/621b8a62-bd79-47fc-948b-d4c4ab3b8588/1.3.6996.39330/XlsxImportExport.dll
ImageRegion
Versione assembly: 2.99.7100.21996
Versione Win32: 2.99.7100.21996
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/2.99.7100.21996/ImageRegion.dll
itextsharp
Versione assembly: 5.5.8.0
Versione Win32: 5.5.8.0
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/2.99.7100.21996/itextsharp.DLL
Svg
Versione assembly: 2.2.0.25027
Versione Win32: 2.2.0.25027
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/2.99.7100.21996/Svg.DLL
SimplePsd
Versione assembly: 1.0.6.0
Versione Win32: 1.0.6.0
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/2.99.7100.21996/SimplePsd.DLL
GhostscriptSharp
Versione assembly: 1.1.0.0
Versione Win32: 1.1
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/2.99.7100.21996/GhostscriptSharp.DLL
MSChart
Versione assembly: 0.1.7164.40842
Versione Win32: 0.1.7164.40842
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/721e858f-fd06-448b-b129-f6f0a2b12bb8/0.1.7164.40842/MSChart.dll
System.Windows.Forms.DataVisualization
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.DataVisualization/v4.0_4.0.0.0__31bf3856ad364e35/System.Windows.Forms.DataVisualization.dll
System.Design
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll
RadioButtonListRegion
Versione assembly: 1.0.7097.30330
Versione Win32: 1.0.7097.30330
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/7336e61c-492b-4735-9bc9-a01d8f57fef1/1.0.7097.30330/RadioButtonListRegion.dll
StatisticalTools
Versione assembly: 1.0.6824.32561
Versione Win32: 1.0.6824.32561
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/76f6e9f5-ac86-4ffb-9e4d-284c8daecaf9/1.0.6824.32561/StatisticalTools.dll
AlgLib
Versione assembly: 1.0.7175.33522
Versione Win32: 1.0.7175.33522
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/8e40b49c-3681-4332-903d-751303860e7b/1.0.7175.33522/AlgLib.dll
SnapshotRegion
Versione assembly: 1.0.7100.22017
Versione Win32: 1.0.7100.22017
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/9166ba14-4cd9-47f6-b988-e96526b16cc9/1.0.7100.22017/SnapshotRegion.dll
BeamAnalysisUtilityFunctions
Versione assembly: 0.1.6825.6494
Versione Win32: 0.1.6825.6494
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/92957269-4fea-4ea0-96e0-93ebdfbaa138/0.1.6825.6494/BeamAnalysisUtilityFunctions.dll
Microsoft.VisualBasic
Versione assembly: 10.0.0.0
Versione Win32: 14.8.3761.0 built by: NET48REL1
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
SADEL
Versione assembly: 0.1.6963.42856
Versione Win32: 0.1.6963.42856
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/950d1b00-188a-4b91-8594-50f926ac0040/0.1.6963.42856/SADEL.dll
LinqBridge
Versione assembly: 1.3.0.0
Versione Win32: 1.3.14717.2012
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/950d1b00-188a-4b91-8594-50f926ac0040/0.1.6963.42856/LinqBridge.DLL
FFTPACK
Versione assembly: 1.0.6825.4311
Versione Win32: 1.0.6825.4311
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/a2e19c35-336f-46e2-9669-25c2cf66b536/1.0.6825.4311/FFTPACK.dll
CFLabelRegion
Versione assembly: 1.0.7100.19488
Versione Win32: 1.0.7100.19488
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/a43ac8f9-29d7-4e8a-9ad0-82cf7c4e14f6/1.0.7100.19488/CFLabelRegion.dll
TextRegionUtilities
Versione assembly: 0.4.7200.15920
Versione Win32: 0.4.7200.15920
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/a9f5e37d-83f5-4a4b-a106-0ba7b202abbb/0.4.7200.15920/TextRegionUtilities.dll
TextRegion
Versione assembly: 1.11.7201.17859
Versione Win32: 1.11.7201.17859
Base di codice: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/TextRegion.dll
PdfFileType
Versione assembly: 1.0.7097.27694
Versione Win32: 1.0.7097.27694
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/ac3d62dc-d93d-4c91-88e2-06a01fd2b5cc/1.0.7097.27694/PdfFileType.dll
PdfSharp
Versione assembly: 1.32.2608.0
Versione Win32: 1.32.2608.0
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/ac3d62dc-d93d-4c91-88e2-06a01fd2b5cc/1.0.7097.27694/PdfSharp.DLL
NPlot
Versione assembly: 0.1.7097.23178
Versione Win32: 0.1.7097.23178
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/aea25225-6b7f-4ce8-9724-49a9b152b415/0.1.7097.23178/NPlot.dll
System.Data
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
ZedGraphRegion
Versione assembly: 0.1.7097.27638
Versione Win32: 0.1.7097.27638
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/b0e7602f-c9d4-4e6c-b6f1-087e4c6e8915/0.1.7097.27638/ZedGraphRegion.dll
CephesMathLibrary
Versione assembly: 1.0.6982.31735
Versione Win32: 1.0.6982.31735
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/b50f73cb-c149-47b1-952a-f95b0c32d6d4/1.0.6982.31735/CephesMathLibrary.dll
mathlib64
Versione assembly: 1.0.6982.31734
Versione Win32:
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/b50f73cb-c149-47b1-952a-f95b0c32d6d4/1.0.6982.31735/mathlib64.dll
PieChartRegion
Versione assembly: 1.0.7097.30323
Versione Win32: 1.0.7097.30323
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/b861ba62-47a3-4c05-a2a5-aa6696d11b52/1.0.7097.30323/PieChartRegion.dll
PathPickerRegion
Versione assembly: 0.1.7100.22621
Versione Win32: 0.1.7100.22621
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/bd70ce3f-ee97-4c22-aa20-acd725feff4e/0.1.7100.22621/PathPickerRegion.dll
XYPlotRegion
Versione assembly: 0.2.7198.38915
Versione Win32: 0.2.7198.38915
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/c12231ec-4873-43c1-a7d0-a167ebd17066/0.2.7198.38915/XYPlotRegion.dll
ModellerRegion
Versione assembly: 1.0.7100.42534
Versione Win32: 1.0.7100.42534
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/d5139464-68f1-4c95-bb0a-66f7ac41f86c/1.0.7100.42534/ModellerRegion.dll
netDxf
Versione assembly: 0.1.2.0
Versione Win32: 0.1.2.0
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/d5139464-68f1-4c95-bb0a-66f7ac41f86c/1.0.7100.42534/netDxf.DLL
GPCWrapper
Versione assembly: 1.0.6824.41024
Versione Win32: 1.0.6824.41024
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/ddc09821-49f1-4c21-a829-6499de0a8f01/1.0.6824.41024/GPCWrapper.dll
ODESolvers
Versione assembly: 0.2.7155.3312
Versione Win32: 0.2.7155.3312
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/ddc09821-49f1-4c21-a829-6499de0a8f06/0.2.7155.3312/ODESolvers.dll
include
Versione assembly: 0.2.7165.16642
Versione Win32: 0.2.7165.16642
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/dfdcd1f7-5005-45f1-8bf8-016fb072ccf3/0.2.7165.16642/include.dll
Run
Versione assembly: 0.2.6975.39277
Versione Win32: 0.2.6975.39277
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/f5b5a1e1-9a13-4f76-93b2-92df19568167/0.2.6975.39277/Run.dll
WizFunctions
Versione assembly: 0.2.7163.1491
Versione Win32: 0.2.7163.1491
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/f78fd28a-4a66-4f62-bed1-28bbf52f63de/0.2.7163.1491/WizFunctions.dll
ComboBoxListRegion
Versione assembly: 1.0.7097.29780
Versione Win32: 1.0.7097.29780
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/fae04ec0-301f-11d3-bf4b-00c04f79efbc/1.0.7097.29780/ComboBoxListRegion.dll
GNUScientificLibrary
Versione assembly: 1.0.7165.41516
Versione Win32: 1.0.7165.41516
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/fc3a9073-15c5-4991-b358-5ae635ae62d5/1.0.7165.41516/GNUScientificLibrary.dll
gsl64
Versione Win32:
Base di codice: file:///C:/Users/sergioW/AppData/Roaming/SMath/extensions/plugins/fc3a9073-15c5-4991-b358-5ae635ae62d5/1.0.7165.41516/gsl64.dll
HTMLFileType
Versione assembly: 1.14.7201.17859
Versione Win32: 1.14.7201.17859
Base di codice: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/HTMLFileType.dll
ImageFileType
Base di codice: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/ImageFileType.dll
PictureRegion
Versione assembly: 1.10.7201.17859
Versione Win32: 1.10.7201.17859
Base di codice: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/PictureRegion.dll
PlotRegion
Base di codice: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/PlotRegion.dll
SMathFileType
Base di codice: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/SMathFileType.dll
StandardToolboxButtons
Versione assembly: 1.1.7201.17859
Versione Win32: 1.1.7201.17859
Base di codice: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/StandardToolboxButtons.dll
ViewerFileType
Versione assembly: 1.1.7201.17901
Versione Win32: 1.1.7201.17901
Base di codice: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/ViewerFileType.dll
XMCDFileType
Base di codice: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/XMCDFileType.dll
System.Windows.Forms.resources
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_it_b77a5c561934e089/System.Windows.Forms.resources.dll
mscorlib.resources
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_it_b77a5c561934e089/mscorlib.resources.dll
System.Drawing.resources
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing.resources/v4.0_4.0.0.0_it_b03f5f7f11d50a3a/System.Drawing.resources.dll
************** Debug JIT **************
Per abilitare il debug JIT, è necessario impostare il valore
jitDebugging nella sezione system.windows.forms del file di configurazione
dell'applicazione o del computer (machine.config).
L'applicazione inoltre deve essere compilata con il debug
abilitato.
Ad esempio:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
Quando il debug JIT è abilitato, tutte le eccezioni non gestite
vengono inviate al debugger JIT registrato nel computer,
anziché essere gestite da questa finestra di dialogo.
best regards
