2 Pages12>
Offline uni
#1 Posted : 15 August 2019 19:58:22(UTC)
uni
Was thanked: 907 time(s) in 511 post(s)
MicroOffice [ β ]
SMath Viewer compatibility mono compatibility Sources
Implementation started.
I don't know how, but I think it is possible to show office documents as images. For editing we can open Word, Excel or Visio as external editors. Documents can be embedded to worksheet.
Edited by user 24 August 2019 06:29:28(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
💰 Support me for plugins development: https://money.yandex.ru/to/410013245578758/100
on 16/08/2019(UTC),  on 16/08/2019(UTC),  on 22/03/2020(UTC)
Offline uni
#2 Posted : 16 August 2019 00:27:29(UTC)
uni
Using this technique it is possible to use the Plotly.js library to draw graphs. Basically, this method allows you to access the usual form, but with limited interaction.
Edited by user 16 August 2019 00:32:12(UTC)  | Reason: Not specified
Russia ☭ forever
Offline overlord
#3 Posted : 29 September 2019 21:02:47(UTC)
Turkey
Was thanked: 34 time(s) in 23 post(s)
This will be a good plugin I think.
Is there any way to show the office document as objects, not as images?
In mathcad when I paste an excel table it is imported as an object.
It can be edited with right click and externally edited as you mentioned for your implementation.
But it is also shown as object and pdf-friendly.
smath.pdf (65kb) downloaded 56 time(s).
mathcad.pdf (285kb) downloaded 40 time(s).
#4 Posted : 29 September 2019 23:04:42(UTC)
Was thanked: 775 time(s) in 615 post(s)
If you want that Excel data table in Smath, easy:
1. capture the Execl, select, crop image
2. copy image, paste in Smath.
The tool is freeware WinGrab.
Offline overlord
#5 Posted : 29 September 2019 23:44:14(UTC)
Turkey
Jean, it is obvious you didn't check the pdf files. You really wouldn't need to tell me about how to crop images if you did, I already did that.
Problem is not how to do it, problem is font render quality. Smath copies excel tables as images, which has no font so no print quality.
1. there is undeniable quality difference between cropped image version (smath), which you mentioned, and font version (mathcad).
2. windows has its own screen capture program that works perfectly. no need to install or keep additional software for this purpose.
3. you actually don't need any software to copy image of excel tables, Ctrl+C is enough. than you can paste it as an image in smath.
But if you make pdf from smath file which has image copied excel table, quality is a disaster.
#6 Posted : 30 September 2019 01:48:04(UTC)
Originally Posted by: overlord Go to Quoted Post
But if you make pdf from smath file which has image copied Excel table, quality is a disaster.
The two PDf look same [I checked both]
That's why I suggested NOT use Microsoft.
If I make an Smath PDF as captured, PDF is 1/1
My PDF is CutePDF freeware, NOT Smath PDF.
#7 Posted : 30 September 2019 02:07:19(UTC)
...open with Adobe Reader [the freeware]
Images captured/crop as described earlier,
pasted in Smath, Smath => CutePDF
Type T_J.pdf (400kb) downloaded 26 time(s).
#8 Posted : 30 September 2019 03:19:40(UTC)
... so simple, so perfect for publishing Smath *.PDF
CosmosPDF.pdf (121kb) downloaded 41 time(s).
Offline overlord
#9 Posted : 30 September 2019 15:24:13(UTC)
Turkey
Please zoom in both pdf. You will see they are not same.
Your last example has the same diseas, if you zoom in to your cosmos.pdf you will see.
Texts in cropped images are not looking good at pdf and paper.
Offline uni
#10 Posted : 30 September 2019 16:16:06(UTC)
uni
Unfortunately, no. As I know for good quality you must use .Net graphic library and there is no simple way to translate graphics from another application. In such projects, I try to find ways to use the existing code to expand the functionality of the program even if the quality of the document decreases. There are so many components that are based on the Control class, it would be great to use at least some of them. Because writing a useful plugin from scratch is very difficult.
Russia ☭ forever
on 30/09/2019(UTC)
#11 Posted : 30 September 2019 17:10:48(UTC)
At right is the original in Smath document.
At left is the 100% Adobe, copied/pasted.
#12 Posted : 30 September 2019 17:18:02(UTC)
Smath document.
PDF Cosmos Test.sm (712kb) downloaded 24 time(s).
After this post, I will re-download check.
#13 Posted : 30 September 2019 17:30:01(UTC)
... re-download sanity checked confirmed 1/1.
Conclusion:
1. NO need for Microsoft for Smath *.PDF
2. Go by the procedure explained above.
3. Procedure presumably applicable to Smath past SS 6179.
4. Check [3] on latest SS.
#14 Posted : 30 September 2019 17:57:54(UTC)
Simply, I don't understand what Microsoft has to do wrt Smath
I used only Paint in my Win 7, a damned poor Paint vs XP Home.
Offline overlord
#15 Posted : 30 September 2019 21:22:41(UTC)
Turkey
Thank you for your kind and explanatory reply. So I have to get on with images.
#16 Posted : 30 September 2019 21:49:33(UTC)
Have you tried: select the Excel table, copy/paste in IrfanView.
Does not => f..k Microsoft Office.
Since Mathcad 8 Pro. select math regions [including table]
copy/paste in IrfanView ... bingo as an image,
copy image, paste in Smath [PDF Cosmos].
I asked for same feature in Smath, apparently was to be
added in SS 6179 < SS Newer.
The alternate captured procedure offered ... few more clicks.
#17 Posted : 30 September 2019 23:21:51(UTC)
Was thanked: 1141 time(s) in 746 post(s)
It is available since version 0.98.6523 Good
#18 Posted : 01 October 2019 00:27:50(UTC)
... then Collab Overlord should try.
Thanks Davide.
Offline Alex M.
#19 Posted : 02 October 2019 21:43:06(UTC)
Alex M.
Was thanked: 119 time(s) in 92 post(s)
EXCEL I/O plugin will plot regions of excel for you without quality loss by using excel_EMF(#) function
https://en.smath.com/for...n-and-export-to-PNG.aspx
A sample of a Plot produced by combination of excel_EMF function and Image Region inside the SMath workbook.
The example was borrowed from one of the calculations by Jean Giraud.
Note the difference of as-printed quality between X-Y Plot output and excel_EMF output.
moody.pdf (93kb) downloaded 58 time(s). Inst_Colebrook MOODY_excelPlot.sm (21kb) downloaded 64 time(s). moody_plot.xlsx (32kb) downloaded 54 time(s).
Edited by user 02 October 2019 21:56:44(UTC)  | Reason: Not specified
thanks 1 user thanked Alex M. for this useful post.
on 03/10/2019(UTC)
Offline overlord
#20 Posted : 03 October 2019 00:36:35(UTC)
Turkey
This has much more render quality than I expected, actually there is no quality loss. Thank you very much.
If combination of excel_IO and image plugin can do this, there should be no reason MicroOffice plugins can't imho.
Smath can even store excel data embedded in *.sm file and it can be viewed without quality loss like your example.
So there won't be any need for an excel file (as a source) for viewing.
2 Pages12>
