3 Pages123>
Offline Novice
#1 Posted : 09 August 2019 14:17:45(UTC)
Novice
Rank: Member
Korea, Republic Of
Dear masters,
I'got the error, "Result is above the max. allowed positive number error" during exponential calculation.
How I resolve this kind of errors?
Thank you!
M.S.
my error
exponential_max_err_v0.sm (13kb) downloaded 18 time(s).
#2 Posted : 09 August 2019 16:09:38(UTC)
Was thanked: 790 time(s) in 626 post(s)
... like this: index 'j' to de-confuse 'i' imaginary.
exponential_max_err_v0.sm (13kb) downloaded 14 time(s).
Offline Razonar
#3 Posted : 10 August 2019 06:44:37(UTC)
Razonar
Uruguay
Was thanked: 280 time(s) in 173 post(s)
Dear masters,
Hi. Summatorie ranged have some issues. For instance, the range variable isn't local. With eval you can get punctual results, but this version can't be plotted, and I don't know why:
Whith this other version you can do both things:
Hope that this helps.
exponential_max_err_v0.sm (14kb) downloaded 10 time(s).
#4 Posted : 10 August 2019 15:08:37(UTC)
... more doctoring in the *.sm attached
1. local definition mode
2. index piece wise
exponential_max_err_v0 (1).sm (25kb) downloaded 7 time(s).
#5 Posted : 10 August 2019 15:39:30(UTC)
... code this to the previous doctored document.
Summation operator is very capricious, but works
and plot scalar as demonstrated. Plot scalar for
lot more involved stuff [Budapest 39, Legendere ...]
Remember Alvaro: you doctored my Barnes Hypergeometric !
Offline Novice
#6 Posted : 13 August 2019 05:43:12(UTC)
Novice
Rank: Member
Korea, Republic Of
Thank you your replies.
But I have a still same problem.
Here are another sample file.
exponential_max_err_v03.sm (19kb) downloaded 10 time(s).
Offline Razonar
#7 Posted : 13 August 2019 07:08:10(UTC)
Razonar
Uruguay
Hi. Yes, it's hard to drive those calculations. Try to avoid sum(1) too:
on 13/08/2019(UTC)
Offline alisonparker
#8 Posted : 13 August 2019 10:13:24(UTC)
alisonparker
Armenia
Dear masters,
Thank you!
M.S.
my error
I am getting error "Result is above max allowed positive number",too! And l don't know how to solve it.Function error
Offline omorr
#9 Posted : 13 August 2019 10:35:54(UTC)
omorr
Groups: Registered, Administrators, Advanced Member
Serbia
Was thanked: 312 time(s) in 266 post(s)
I think something is wrong here in the numeric/symbolic engine of SMath which causes those errors.
Version "0.99.7109"
I can not understand this Crazy . The error message is quite confusing. The result is quite a small number close to zero. On the other hand, by mouse hoovering the vector it could be seen the fraction presentation of the numbers (symbolic engine) with quite large numbers in the denominator. Therefore the message about max. allowed positive numbers. I think something is wrong in the floating point arithmetic in SMath numerical engine or at least quite problematic. It seems that eval() must be used extensively in order to escape from these traps and to avoid the symbolic engine to make a mess here.
Edited by user 13 August 2019 12:36:49(UTC)  | Reason: Not specified
#10 Posted : 13 August 2019 15:49:55(UTC)
But I still have same problem.
Hello Novice ...
I can't see what you are attempting.
Are you trying to fit a model function to a data set ?
If so: just attach the data set, some smart cat will exercise.
A maths document that has no hint about ... Oh !
#11 Posted : 13 August 2019 17:03:24(UTC)
Version "0.99.7109"
From observation in many more SS 7109, the indexing is freaked.
Doctored in pink SS 6179.
exponential_max_err_v03.sm (18kb) downloaded 5 time(s).
Offline Novice
#12 Posted : 13 August 2019 17:08:02(UTC)
Novice
Rank: Member
Korea, Republic Of
Dear jean,
I'm just doing the calculation of an ANS standard example.
I think this problem is a kind of overflow of exponential function.
As you know if X is greater than the 709.783 then the value of exp(X) is overflown.
So I believe that SMath should do something to check the nominal boundaries of special functions (exponential, logarithmic etc.)
Thank you!
regards,
MS
Edited by user 14 August 2019 03:57:06(UTC)  | Reason: Not specified
#13 Posted : 13 August 2019 17:34:52(UTC)
Thank you!
Thanks for the hint.
Functions that overflow can be managed otherwise.
About that project, just give the X,Y data you want to fit.
Smath reports overflow as "max value ..."
All those math functions aren't Smath, rather from numerical library
as implemented in Microsoft and other maths tools.
Ah! I can see XY pairs coming soon.
Offline omorr
#14 Posted : 13 August 2019 19:08:21(UTC)
omorr
Serbia
Version "0.99.7109"
Still confused...Unsure
exponential_max_err_v03-corr.sm (32kb) downloaded 9 time(s).
#15 Posted : 13 August 2019 22:19:16(UTC)
Still confused...
Doctored a bit SS 6179 ... No red in No time.
exponential_max_err_v03-corr.sm (33kb) downloaded 9 time(s).
#16 Posted : 13 August 2019 23:03:20(UTC)
... from there => what's next step ?
exponential_max_err_v03-corr [Next].sm (40kb) downloaded 4 time(s).
#17 Posted : 14 August 2019 03:27:11(UTC)
... from there what's next =
... does the suite in green makes sense ?
That mystic formula has to be put in executable maths
exponential_max_err_v03-corr [Next-Suite].sm (161kb) downloaded 8 time(s).
#18 Posted : 14 August 2019 07:17:41(UTC)
Please, check my interpretation.
exponential_max_err_v03-corr [Next-Suite].sm (186kb) downloaded 5 time(s).
Offline omorr
#19 Posted : 14 August 2019 09:20:01(UTC)
omorr
Serbia
Still confused...
Still red for me...
#20 Posted : 14 August 2019 16:04:59(UTC)
Still red for me...
Radovan, mon ami ... you must feel Sysyphus on that boulder !
I figure the all project is as simple as in the attached SS 6179.
Novice didn't give enough ... wait and see.
On the other hand your red is for Grand Doctor Andrey.
Fission.sm (134kb) downloaded 11 time(s).
Similar Topics
[SS-3575] Potential-exponential function error (Bugs & Problems)
by Razonar 15/10/2018 19:08:46(UTC)
3 Pages123>
