π Links: 1. How to create plugins for SMath Studio2. Command-line build with csc.exe3. Template project for numerical plugin (VS2017, .Net 2.0+, C#)4. SMath Studio Core documentation (CHM) 5. Developer Guide (partially obsolete) For c#: 1. Create file build.cmd
Code:::Autor: Viacheslav N. Mezentsev (viacheslavmezentsev@ya.ru)
@echo off && cls
set dotnet=%windir%\Microsoft.NET\Framework64
if "%~x1" == ".cs" set lang=cs
if "%~x1" == ".vb" set lang=vb
for %%n in (2.0.50727,3.5,4.0.30319) do if exist "%dotnet%\v%%n\%lang%c.exe" set comp="%dotnet%\v%%n\%lang%c.exe"
if exist %comp% (
%comp% -nologo ^
-target:library ^
-lib:"%ProgramFiles(x86)%\SMath Studio" ^
-reference:System.Xml.dll,System.Data.dll,SMath.Controls.dll,SMath.Manager.dll,SMath.Math.Numeric.dll,SMath.Math.Symbolic.dll ^
-out:"%~n1.dll" %1 ) && echo SMath plugin: "%~n1.dll"
2. Create source file CSTinyPlugin.cs
Code:using System;
using System.Reflection;
using System.Runtime.InteropServices;
using System.Collections.Generic;
using SMath.Manager;
using SMath.Math;
using SMath.Math.Numeric;
[assembly: AssemblyTitle( "CSTinyPlugin" )]
[assembly: AssemblyDescription( "Template project for numerical plugin." )]
[assembly: AssemblyVersion("0.1.*")]
// NOTE: Each plugin must have unique GUID. Use online guid generators for this.
[assembly: Guid("3F8D4EC4-637C-4E5E-95D1-4F0422B71A27")]
public class Plugin : IPluginMathNumericEvaluation
private TermInfo[] _terms;
private Dictionary<string, string> _description = new Dictionary<string, string> { { "ENG", "mult function." }, { "RUS", "ΡΡΠ½ΠΊΡΠΈΡ ΡΠΌΠ½ΠΎΠΆΠ΅Π½ΠΈΡ." } };
public TermInfo[] GetTermsHandled( SessionProfile sessionProfile )
return _terms;
public void Initialize()
_terms = new[] {
new TermInfo (
"mult", TermType.Function, _description[ "ENG" ], FunctionSections.Unknown, true,
new[] { new ArgumentInfo( ArgumentSections.RealNumber ), new ArgumentInfo( ArgumentSections.RealNumber ) }
public bool NumericEvaluation( Term value, TNumber[] args, ref TNumber result )
result = args[0] * args[1];
return true;
public void Dispose() {}
3. Build assembly using command: build CSTinyPlugin.csAlso you can use drag and drop technique for this. You get CSTinyPlugin.dll 5. Copy CSTinyPlugin.dll to the C:\Program Files (x86)\SMath Studio\plugins folder and restart the program. 6. Test it. 7. Read the SMath Studio Core documentation: SSCoreDoc.chm. Edited by user 13 August 2019 15:27:55(UTC)
Russia β forever Viacheslav N. Mezentsev |
on 06/08/2019(UTC), on 07/08/2019(UTC)
π Links: 1. How to create plugins for SMath Studio2. Sample compilation command lines (Visual Basic)3. Template project for numerical plugin (VS2017, .Net 2.0+, VB.Net)4. SMath Studio Core documentation (CHM) 5. Developer Guide (partially obsolete) For vb.net: 1. Create file build.cmd
@echo off && cls
if exist %comp% (
%comp% -nologo ^
-target:library ^
2. Create source file VBTinyPlugin.vb
Code:Imports System
Imports System.Reflection
Imports System.Runtime.InteropServices
Imports System.Collections.Generic
Imports SMath.Manager
Imports SMath.Math
Imports SMath.Math.Numeric
<Assembly: AssemblyTitle("VBTinyPlugin")>
<Assembly: AssemblyDescription("Template project for numerical plugin.")>
<Assembly: AssemblyVersion("0.1.*")>
' NOTE: Each plugin must have unique GUID. Use online guid generators for this.
<Assembly: Guid("FB41BCBC-11EC-4D8D-BDE1-C5772608EEA9")>
Public Class Plugin
Implements IPluginMathNumericEvaluation
Private _terms As TermInfo()
Private _description As Dictionary(Of String, String) = New Dictionary(Of String, String) From {
{"ENG", "mult function."},
{"RUS", "ΡΡΠ½ΠΊΡΠΈΡ ΡΠΌΠ½ΠΎΠΆΠ΅Π½ΠΈΡ."}
Public Function GetTermsHandled(sessionProfile As SessionProfile) As TermInfo() Implements IPluginHandleEvaluation.GetTermsHandled
Return _terms
End Function
Public Sub Initialize() Implements IPlugin.Initialize
_terms = {New TermInfo("mult", TermType.[Function], _description("ENG"), FunctionSections.Unknown, True,
{ New ArgumentInfo(ArgumentSections.RealNumber), New ArgumentInfo(ArgumentSections.RealNumber)}) }
End Sub
Public Function NumericEvaluation(value As Term, args As TNumber(), ByRef result As TNumber) As Boolean Implements IPluginMathNumericEvaluation.NumericEvaluation
result = args(0) * args(1)
Return True
End Function
Public Sub Dispose() Implements IDisposable.Dispose
End Sub
End Class
3. Build assembly using command: build VBTinyPlugin.vbAlso you can use drag and drop technique for this. You get VBTinyPlugin.dll 5. Copy VBTinyPlugin.dll to the C:\Program Files (x86)\SMath Studio\plugins folder and restart the program. 6. Test it. 7. Read the SMath Studio Core documentation: SSCoreDoc.chm. Edited by user 07 August 2019 18:13:55(UTC)
