Was thanked: 16 time(s) in 7 post(s)
Andre et all-
Would you consider adding an option box for the default file save type? I would like to set SMath to default to .smz instead of .sm. I realize that I am probably in the minority but want to throw it out there.
Thanks
sinneD
Originally Posted by: sinneD Would you consider adding an option box for the default file save type? I would like to set SMath to default to .smz instead of .sm. I realize that I am probably in the minority but want to throw it out there. Once you have constructed the Smath document, including miscellaneous stuff "files". you can save *.sm or *.smz Then isn't true that at re-opening *.smz you recover the file stuff as well ?
Originally Posted by: Jean Giraud Once you have constructed the Smath document, including miscellaneous stuff "files". you can save *.sm or *.smz Then isn't true that at re-opening *.smz you recover the file stuff as well ? ... on the other hand: not every/any Smath piece can be saved to file ... i.e: the collector { can't be saved to file, saved it otherwise vector style.
