Offline pdalet
#1 Posted : 16 May 2019 11:49:52(UTC)
pdalet
Rank: Member
France, Metropolitan
Was thanked: 10 time(s) in 6 post(s)
I work mainly with ubuntu (16.04 and 18.04). Save as PDF file does not work and print with cups-PDF printer also.
To print correctly, I need to save as PNG file: many pages in a single file.
Is it possible to save in many files as : corr-1.png (page 1 A4) corr-2.png (page 2) ..... ?
Thanks a lot
Philippe DALET
Lycée Champollion
Laboratoire de Physique-Chimie
FIGEAC - FRANCE
#2 Posted : 16 May 2019 16:27:18(UTC)
Was thanked: 791 time(s) in 627 post(s)
I don't understand something in there:
Assume you are in a Smathh session, and you have a project in hand.
Saving as *.PNG is non-sense as it is an improved *.BMP, i.e: a huge image !
If you want to save the Smath document as *.PDF ... easy:
1. Download/install freeware CutePDF [works well for me]
2. Click on Smath "Print", select CutePDF as the virtual printer
3. Click OK ... wait the conversion is finished.
4. Given a document name, save in your master C:\PDF root directory
5. Done ... open your document from C:\PDF, double click
here is the document on screen.
That's how Jean is doing Win 7 Smath version 6179.
Sorry Philippe, can't help more.
#3 Posted : 16 May 2019 19:16:49(UTC)
Was thanked: 1152 time(s) in 756 post(s)
Hello Philippe, as for the pdf I doubt we can do much since the conversion is mostly done by external libraries; we might see if there is something that works better on linux (IDK at the moment). As for the image export I remember that I've done something for myself a very long time ago, so it might be possible.
#4 Posted : 17 May 2019 01:44:29(UTC)
Philippe,
Are you asking to save a Smath document as *.BMP *.PNG ?
Open WinGrab, start capture F11 [that's my key code capture]
At this point you have a full screen captured,
then: select via selection tool, crop image.
then save as: *.BMP *.PNG *.TTF check what else.
Proceed over the all pages of your Smath document.
Latest IrfanView has capture facility as well,
PrintScreen, paste in Paint, select region, copy/paste in
IrfanView or WinGrab ... save as.
IrfanView will allow lot many image processing [Sharpen,
Inverse color, Rotate at in multiple directions, add text ...]
Offline pdalet
#5 Posted : 19 May 2019 20:13:43(UTC)
pdalet
Rank: Member
Hello Jean
I work on linux (ubuntu 16.04 and 18.4). Smathstudio works very fine on linux, except when I print with cups-pdf (pdf printer) and except when I save as a pdf file (pdf extension).
Also I save as an image file (png). I send to my students for their project an image file (A4 width and a big height).
The solution is that the pdf extension works on linux. I'm not an expert on mono and the extension seems to work only on windows.
Save in many files as corr-1.png (page 1 A4) corr-2.png (page 2) with A4 width and A4 height is another solution.
Philippe
Offline Razonar
#6 Posted : 19 May 2019 22:12:02(UTC)
Razonar
Uruguay
Was thanked: 292 time(s) in 181 post(s)
Hi. And if you save the file as html and then print it from you explorer as pdf?
#7 Posted : 20 May 2019 01:18:18(UTC)
Hello Jean
If you can't do what you want with Ubuntu, then use Smath Win 7.
It will save *.PDF same size as on Smath screen.
The other problem you mention is freaked size from Ubuntu as *.PNG.
The capture technique [IrfanView, WinGrab] captures the screen as an image,
thus does not freak size, similar to Paint except from Paint you can't
IrfanView save as *. 20 types.
Neither Mathcad/Mathsoft would save a document as *.PNG
What I don't understand => if Ubuntu saves *.PDF as you wish,
why bother saving in other style. Whatever, the bug is Ubuntu.
Obviously Smath can't doctor the dead.
Offline pdalet
#8 Posted : 20 May 2019 13:16:36(UTC)
pdalet
Rank: Member
Hello
SmathStudio can't save as pdf file correctly. The file is generated with only the header and the footer of the page. A windows dll is needed.
I have not tested SmathStudio (windows) with wine.
I have saved a SmathStudio file as a tex file: the problem is the same: it doesn't work . The only solution for me is to save as an image file on Ubuntu.
Philippe
#9 Posted : 20 May 2019 14:59:10(UTC)
It's not Smath that saves as *.PDF, rather the virtual PDF installed
My system does everything as demanded [except singing a song].
Smath 6179, Win 7 1.66GHz, 10.1"
Freeware: Adobe reader, IrfanView, WinGrab + + +
IrfanView is a MUST to read documents that Windows can't.
Mach is the Smath work sheet captured WinGrab, saved *.PNG WinGrab.
WinGrab is the top best *.PNG for images that have lot colors.
It does not apply to a math document, but from other image creator.
Doublet from virtual CutePDF ... 1/1 Smath work sheet.
Maybe you have to recycle Ubuntu for Win 7 [known nothing about Wine].
Please, let us know where you stand about a working system.
Doublet.pdf (29kb) downloaded 10 time(s).
#10 Posted : 21 May 2019 14:59:18(UTC)
Offline pdalet
#11 Posted : 29 May 2019 12:56:34(UTC)
pdalet
Rank: Member
2A4.zip (282kb) downloaded 24 time(s).
A simple script in python to solve the problem.
Philippe DALET
#12 Posted : 29 May 2019 16:47:47(UTC)
The Smath file does not open ?
The native image is 4 MB, reduced color 0.7 MB.
What does Python do that previous proposals didn't ?
Offline pdalet
#13 Posted : 31 May 2019 18:03:46(UTC)
pdalet
Rank: Member
2A4.zip (283kb) downloaded 10 time(s).
I modified the script 2A4.py for windows (output file with no .png extension).
tested with python 3.7.3 on win7 and ubuntu 1804 (64 bits)
Package pillow needed
I opened correctly the file "CD Corr.sm" on win7 and ubuntu. The image file is about 157 kb. I don't know how to modify the resolution of the output. The standard outpu resolution is 72 ppi.
Windows 7 & Ubuntu 1804
width x height
Philippe.
