I don't have supporting example(s), easy to think of something. Suppose your experimental data result in histogram(s) per say, that you can fit by a parametric model function. Then, each experiment will be personalized from which the observer will render valid information ... optimizing the process from more savant Process Control manipulations. Jean Integrate_00000000 [Algo at(3) Range-Observer].sm (15kb) downloaded 19 time(s).
