Joined: 20/03/2019(UTC) Posts: 73 Location: Mandeville, LA
I have a long formula, it will not fit on one line in a standard sheet. I can't see what I am typing, and can't tell if the formula is correct. What do I need to do to see it? If I put a return in the formula, to continue it on the next line, it still does not work.
Originally Posted by: Britt1 I have a long formula, it will not fit on one line in a standard sheet. I can't see what I am typing, and can't tell if the formula is correct. What do I need to do to see it? If I put a return in the formula, to continue it on the next line, it still does not work. Get used to attach the Smath work sheet. Only patient can be doctored.
1 user thanked CBG for this useful post.
Originally Posted by: Britt1 I have a long formula, it will not fit on one line in a standard sheet. I can't see what I am typing, and can't tell if the formula is correct. What do I need to do to see it? If I put a return in the formula, to continue it on the next line, it still does not work. There are surely ways to simplify/split/compact/collect a formula from foreign source or from invented construction as understood from your typing. Examine Hypersurface. The other long expansion arrive from symbolic expansion [eq(t) from maple invlaplace] For that one, you can recompose by separating NumDen. Isolate Num, evaluate the pieces, substitute ... etc. Recompose the all lot in shorter expression. The longest expansion I have encountered was 23 pages wide. There are several ways to skin the cat. Does it help ? NumDen.sm (18kb) downloaded 28 time(s). Contour_8 Hypersurface.sm (1,192kb) downloaded 25 time(s).
Have you got the same ? easy to sanity check.
