SMath Studio Forum
Questions
wfile function fractional output
Hi Everybody,
I am trying to export (i.e., write to a text file) a vector of decimal numbers. With wfile function, I am only able to get fractional representation of data available. Is it possible to export numbers in decimal format only or should I convert them in Excel manually at the moment?
I will appreciate any other suggestion (other plugin or function) as an alternative.
Joined: 23/12/2011(UTC) Posts: 318 Location: italy Was thanked: 109 time(s) in 93 post(s)
You can use the "Data Exchange" plugin -> "ExportData.CSV" function
Originally Posted by: PompelmoTell You can use the "Data Exchange" plugin -> "ExportData.CSV" function
sergio Solved. Many Thanks Sergio Edited by moderator 05 April 2019 13:58:27(UTC)
| Reason: marked as solved
Originally Posted by: Koray Kadas With wfile function, I am only able to get fractional representation of data available. If the data 'frac' is long enough, Ω will show truncated enclose [Ω]= for full length ... [,] from matrix palette 1 row, 1 col.
SMath Studio Forum
Questions
