Offline mytam
#1 Posted : 28 March 2019 07:43:16(UTC)
mytam
When creating a new matrix, it would be faster, and more natural to type ctrl+m 2,3 <return>
rather than use both row and column fields
For me personally, the default for columns would best be 1, that is what I use more often than anything else.
I also find filling matrices slow and difficult. It would be much easier to comma delimit data in columns, and semi-colon delimit rows. This would make it easy to fill either across or down. When reaching the end of a row/column, it would wrap to the next (regardless of "," or ";" )
The problem with tab is that it is with keys 1,2,3 + tab is it's a left hand cack handed stretch to the tab key that gets capslock every time, for me. - so I have to do it slowly.
Using comma is left-right-left-right and flows smoothly. (This is the same reason that // is my favourite comment character regardless of language - it flows whereas eg. shift+# never does)
Offline Razonar
#2 Posted : 28 March 2019 10:22:06(UTC)
Razonar
Uruguay
Was thanked: 156 time(s) in 99 post(s)
Hi mytam. Isn't very natural, but with this you only need one click.
1) Write ma( into a math area. Then the parenthesis close, and you see ma(_)
2) Write the matrix elements file to column. For example, for a 2x3 matrix, you get: ma(11,12,13,21,22,23)
3) Write the number of files and columns. You get now ma(11,12,13,21,22,23,2,3)
4) Finally, click after "ma" and complete typing a "t". Then mat(11,12,13,21,22,23,2,3) is showing as what it is: a 2x3 matrix.
Or as image, more explicit:
on 28/03/2019(UTC)
#3 Posted : 28 March 2019 16:23:52(UTC)
Was thanked: 665 time(s) in 517 post(s)
No short way to fill a matrix ! by hand.
Toke me ½ day to fill 767*2 HadCRU Global Warming data.
The suggested approach is best as you can see side by side
what you fill-in from the source data image.
Offline Andrey Ivashov
#4 Posted : 01 April 2019 01:30:03(UTC)
Was thanked: 1554 time(s) in 520 post(s)
It is possible with newest release (build 7030). Arguments separator symbol allows you to move focus from rows to columns box now.
Hope this will help you.
#5 Posted : 01 April 2019 03:20:04(UTC)
What more convenient and logic than SS 6179 can be invented ?
fill the first top left -> cursor fill next -> ...
as the last column is filled: drops down next row left
... and so on
negative number: twice cursor ->-> move next.
From the matrix tool box, easy to insert a missing row.
Creating a matrix is a delightful part of a project.
Creating matrix from f(x), f(x,y) is even simpler.
Similar Topics
Speed matrix creation and filling with comma (Feature Requests)
by crun 04/05/2018 10:11:04(UTC)
