Joined: 20/03/2019(UTC) Posts: 73 Location: Mandeville, LA
What does the special functions addin do, and how do you add it to the sheets?
Originally Posted by: Britt1 What does the special functions addin do, and how do you add it to the sheets? Special functions is too large a word: anything that does something wrt maths is a special function [Floor, Ceil, round, abs ...] You can have lot more functions from already developed for purpose. Gamma(x) 15 D, Si, Ei, Li, Polylog, Polygamma, Dawson, Whittaker, plenty poly orthogonal, plenty distributions ... Airy CoC Essential Fourier, Bessel from the f(x) menu Already quite a few distributions from f(x) menu. Better than plugin is a collection in work sheet. that you can call via the command "include". What's your wish list ...
Hi Britt. Actually SpecialFunctions isn't an "external" plugin, it was, but not any more. From an old SMath update: "New functions added to the SpecialFunctions built-in plugin: importData(..), str2num(), num2str(), concat(..), findstr(.), substr(.), substr(..), strrep(..), strlen(), IsString() and error();" So, it have some useful function, but not the usual math "SpecialFunctions". You can found them at other numerical plugins, like: https://en.smath.com/for...tst1775_AlgLib-3-1x.aspxhttps://en.smath.com/for...tst1918_DotNumerics.aspxhttps://en.smath.com/for...Cephes-Math-Library.aspxbut this list ins't complete. Best regards. Alvaro.
Hello, go to insert > functions... and play with the plugins dropdown to see what functions are carried by each plugin, also by Special Functions |
Was thanked: 16 time(s) in 7 post(s)
Kinda like this..... |
