If this has been previously noted, I apologize. If I open this .sm file from clicking on the file in the directory, it works and reads the data file; however, if I start Smath and then open the file from Smath it does not read the file. DATA.txt (2kb) downloaded 16 time(s). FILE READ TEST.sm (4kb) downloaded 19 time(s).
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,653 Location: Italy Was thanked: 1340 time(s) in 879 post(s)
Confirmed, thank you! Edited by user 28 February 2019 12:50:15(UTC)
| Reason: added BTS-ID |
Originally Posted by: JRC If I open this .sm file from clicking on the file in the directory, it works and reads the data file; however, if I start Smath and then open the file from Smath it does not read the file. Something you are not going correct: 1. Copy the DATA from your download 2. Paste in your Smath file directory 3. close session ... open Smath session 4. address the CWD:= 5 read back
Also, my path is very long and I have had trouble copying the path from the windows folder and pasting into the argument of inputData.
Should have said, my path is very long and I have had trouble copying the path from the windows folder and pasting into the any Smath argument.
Still does not work for my file structure. Don't think I will change my file structure for this one program.
Originally Posted by: JRC Should have said, my path is very long and I have had trouble copying the path from the windows folder and pasting into the any Smath argument. CWD = Current Working Directory. 1. In your C:\ ... create the SmathFile directory. 2. From your Windows "Download" 3. Copy DATA... 4. Paste in your Smathfile from where you read. Tip: once you can read [I suggested 'read'] Explode read in expanded vector [read]= Copy the data in a new assigned vector ... now you can plot. I played a bit from direct reading but Smath complained and crashed the work sheet. That's why you have to isolate the vector, Then you will play at will with that monkey branching. Cheers ... Jean
Originally Posted by: JRC Still does not work for my file structure. Maybe you don't have an efficient file structure. In my "SmathFle", all sorts of Smath items: data sets, formulas, images I Constantly graze for utilities, models, projects ... average browsing time among ~ 2000 documents < 15 seconds.
Originally Posted by: Jean Giraud Tip: once you can read [I suggested 'read'] Explode read in expanded vector [read]= Copy the data in a new assigned vector ... now you can plot. ... like this:
Originally Posted by: Jean Giraud I played a bit from direct reading but Smath complained and crashed the work sheet. That's why you have to isolate the vector, Your data are in the document cw with the plot. You can inspect down to lower values of X, but going for too low values it will crash Smath in the too low values of X around 0.0000XXXXX Your lowest value is 0.000000000000XXX At so low values crash. Smath does not plot at so low values and crash File READ Txt.sm (14kb) downloaded 11 time(s).
