Offline Farja
#1 Posted : 26 February 2019 17:47:01(UTC)
Farja
Chile
I was having problems importing an excel file, thought it was a problem with the extension, but some sheets continued to work. The problem was due to the name of the file used as argument to the plugin.
The only difference between the strings shown below, is that in the first case the name was copied from a windows explorer window and pasted between ""(lazy me Confusion ), and the other was typed directly.
Both look the same, but SMath stores them differently, and when passed as an argument to the plugin, it fails.
Var_String1:
Code:
      <math>
        <input>
          <e type="operand">var_string1</e>
        </input>
        <result action="numeric">
          <e type="operand" style="string">M2U4\005F\m03\005F\2\005F\Error\002E\xlsx</e>
        </result>
      </math>
Var String2:
Code:
      <math>
        <input>
          <e type="operand">var_string2</e>
          <e type="operand" style="string">M2U4_m03_2_Error.xlsx</e>
          <e type="operator" args="2">:</e>
        </input>
      </math>
Error ST.sm (5kb) downloaded 11 time(s).
Excel plugin:
https://en.smath.info/fo...yaf_postst4375_Plugin---EXCEL--2003--I-O-with-recalculation-and-export-to-PNG.aspx
thanks 1 user thanked Farja for this useful post.
on 26/02/2019(UTC)
#2 Posted : 26 February 2019 21:53:54(UTC)
XlsxImportExport plugin updated; please let me know if it works properly so I'll update similar plugins.
Offline Farja
#3 Posted : 26 February 2019 22:57:51(UTC)
Farja
Chile
Thanks Davide, i was using the Excel I/O plugin (EXCEL (2003+) I/O with recalculation and PNG export - 1.99.6849.42653), but the problem also applies to XlsxImportExport plugin.
The updated XlsxImportExport plugin (1.3.6996.39330) work properly with the same problematic strings (space, underscore, dot, etc). So i will switch to this one.
Best regards,
Farja
#4 Posted : 27 February 2019 02:57:46(UTC)
Originally Posted by: Farja Go to Quoted Post
i was using the Excel I/O plugin (EXCEL (2003 ) I/O with recalculation and PNG export
Updated. Good
Offline Farja
#5 Posted : 28 February 2019 20:39:48(UTC)
Farja
Chile
Thanks Davide,
Both plugins work fine now.
Best regards,
Farja
Edited by moderator 01 March 2019 21:10:06(UTC)  | Reason: marked as Solved
