SMath Studio Forum
Samples
Temperature [-273.15 ... 1084.5 °C]
These 3 Smath documents are minimalist: Scientific/Engineering/Edu. 1. Germanium sensors as Secondary Standard ... as delivered 2. Pt sensors as Primary Standard [check more for their range]. 3. Thermocouples T/C types T, J for industrial applications. You may afford an household cheap thermometer. In 1977, the Nuclear Power Plant I used to work had several temperature points @ 10000 $ each ... just a peanut ! Enjoy those calculators ... any questions ? Cheers ... Jean Inst_Type T_J NBS 125 Copy.sm (118kb) downloaded 32 time(s). Inst_Type Ge Copy.sm (221kb) downloaded 25 time(s). Inst_Type Pt100 Reconciliation Copy.sm (537kb) downloaded 34 time(s).
Originally Posted by: Jean Giraud Enjoy those calculators ... any questions ? ... this document reconciliates the previous Pt100 Calculator. 1. It is all inclusive for tracability 2. Guidance for calibrating the loop. 3. eit90 decimals respected. Jean Inst_Type Pt100 CALCULATOR Copy.sm (109kb) downloaded 28 time(s).
SMath Studio Forum
Samples
