Joined: 22/10/2018(UTC) Posts: 22 Location: Saarbrücken
Hello, the Integration function doesnt seem to work in the right way. Edited by moderator 31 January 2019 21:56:25(UTC)
| Reason: Not specified
Originally Posted by: G-Tate the Integration function doesnt seem to work in the right way. 1. Integration is over an integrand, here you have a constant 2. Squeeze the math regions, capture those regions to reduce the image 3. Doctoring is best with the work sheet.
Originally Posted by: Jean Giraud 1. Integration is over an integrand, ... the Smath integration operator is Simpson. id: it ranges from very accurate up to 15 and ranges from absolute crap !!! That suggest the WS for doctoring. Maths Beginner_2 [ln(x), exp(x)].sm (39kb) downloaded 19 time(s).
