Online Andrey Ivashov
#1 Posted : 10 May 2009 06:23:15(UTC)
Here is complete list of shortcuts built-in into SMath Studio:
Inserting
  • Ctrl+M - Insert Matrix
  • Ctrl+E - Insert Function
  • Ctrl+T - Insert blank Image
  • Ctrl+Shift+P - Insert PI constant (3.1415...)
  • Ctrl+Shift+Z - Insert Infinity
  • \ - Insert square root
  • Ctrl+\ - Insert n-th root
  • [ - Insert el() function - subscript
Calculating
  • Ctrl+. - Symbolic calculation of the equation
Editing
  • Ctrl+Z - Undo changes
  • Ctrl+Y - Redo changes
  • Ctrl+X - Cut
  • Ctrl+C - Copy
  • Ctrl+V - Paste
  • Ctrl+A - Select all page controls / Select all inside the control (depends on cursor position)
Standard
  • Ctrl+N - Create a new page
  • Ctrl+F4 - Close current page
  • Ctrl+P - Print current page
  • Ctrl+O - Show open file dialog
  • Ctrl+S - Save current page
Edited by user 10 May 2009 06:34:33(UTC)  | Reason: Not specified
Offline mar
#2 Posted : 13 September 2009 20:28:28(UTC)
mar
Rank: Member
Is this table of short cuts available from within the tool? If not than it should be. As an item on the tool bar or as a ref book?
Offline omorr
#3 Posted : 13 September 2009 20:38:50(UTC)
omorr
Serbia
Hello Mike,
The table of short cuts is not completed - some new ones are introduced very recently. Also, it has mentioned many times that the Reference or Tutorial material is not yet available. We just need some patience Good
Offline casanunda
#4 Posted : 30 September 2009 15:43:48(UTC)
casanunda
These shortcuts are very helpful and make entering formulas a lot faster.
I have one problem though:
in German keyboard layout, some special characters (like the "\" and thes "[" or "] ) have to be entered by pressing the "ALT GR" key together with another key.
None of these Key combinations work for me when I try to enter them in SMath Studio.
This is especially annoying for the backslash, because square roots are not that incommon...
Offline Greg Locock
#5 Posted : 30 September 2009 17:56:51(UTC)
Greg Locock
Incidentally if you want the complete list, or have found a new one, see the Wiki, link at the yellow button at the top of the webpage.
