Offline Andrey Ivashov
#1 Posted : 07 September 2018 23:17:53(UTC)
Was thanked: 1977 time(s) in 665 post(s)
SMath Studio - SMath
Created by Andrey Ivashov in the scope of SMath project. Published by smath.
SMath Studio box
Version 1.0.8348 - Stable (released at )
Downloads: 1702337 Download
Open in browser
Changes history
Great instrument. Thanks more...
by Antonio Fazzutti
trop bien ce programme....pour faire de fiches de calcul. en plus on peut ouvrir des fiches Mathcad sans souci aucun. more...
by aedes
An amazing math tool, a must-have for engineers and scientists everywhere. (And it's not bad as a quick expression evaluator, either.) more...
by Mike Williams
Please note: this release requires almost all plug-ins to be adopted. I'm working on it right now.
About 50% (most used) of plug-ins are already updated, others will be updated soon.
thanks 6 users thanked Andrey Ivashov for this useful post.
on 08/09/2018(UTC),  on 08/09/2018(UTC),  on 08/09/2018(UTC),  on 08/09/2018(UTC),  on 08/09/2018(UTC),  on 19/09/2018(UTC)
Offline mkraska
#2 Posted : 08 September 2018 01:31:45(UTC)
mkraska
Was thanked: 1060 time(s) in 677 post(s)
Andrey,
prior to your API adjustments I committed some improvements to the Maxima Plugin. Is there a way to publish these also for build 6671 (except by temporary reverting and afterwards re-committing your changes)?
I think of pointing not just to the SVN path but also to a particular SVN revision in the release manager.
Would the above-mentioned procedure worth the effort or do you consider support of 6671 now being obsolete?
EDIT: I found out how to do it: just append the revision to the path:
https://smath.info:8443/svn/public/plugins/MaximaPlugin@2740
Edited by user 08 September 2018 02:04:02(UTC)  | Reason: Not specified
on 16/09/2018(UTC)
#3 Posted : 08 September 2018 02:05:38(UTC)
Hello Martin.
Of course it is possible to revert changes, make an update/release and re-apply initial changes again. It will take some time, but we can do it if you wish (let me know if any help is required).
I plan to release new stable version in 1 or 2 weeks. Actually I needed this beta just because not all plug-ins are ready and tested. So if your changes are not very urgent then it may be more convenient to wait a bit. But it is up to you!
on 08/09/2018(UTC)
Offline mkraska
#4 Posted : 08 September 2018 02:17:45(UTC)
mkraska
Originally Posted by: Andrey Ivashov Go to Quoted Post
Hello Martin.
I wasn't aware of that the release manager accepts SVN paths with revision tag (should have asked this to google before asking here). This did the trick, so the Maxima Plugin is updated for 6671 stable and 6824 beta without messing with the repository.
BTW thanks for doing all the API adjustment work for us!
on 08/09/2018(UTC)
Offline mkraska
#5 Posted : 08 September 2018 15:49:05(UTC)
mkraska
The Extension manager in 6824 doesn't fetch the correct version of the Maxima plugin. Andrey has released a stable version of the plugin for 6824 and later I did a stable version for 6671. Now 6824 always downloads the version for 6671 and then complains that installation fails.
I'd expect that the specification of which SMath is used for release is honoured by the extension manager. How can this be resolved?
#6 Posted : 08 September 2018 15:56:06(UTC)
Was thanked: 1301 time(s) in 857 post(s)
Any release is for the targeted version and later, thus you have to publish several releases targeting from the older target to the newer (first make a release for 6671, then make another for the latest)
on 08/09/2018(UTC)
Offline mkraska
#7 Posted : 08 September 2018 17:55:12(UTC)
mkraska
The problem was that the plugin has been released for 6824 before it was released for 6671. Repeating the release without any changes for 6824 seems to solve the problem. Maxima now loads correctly in 6824. Yet, due to lack of other important plugins (custom glyphs, X-Y plot) fun is limited in that version.
Offline uni
#8 Posted : 08 September 2018 18:34:35(UTC)
uni
Was thanked: 1243 time(s) in 724 post(s)
As for the X-Y Plot and other (ZedGraph, NPlot). New API does not fully cover the requirements of these plugins. For now I can't port X-Y Plot.
Russia ☭ forever
Viacheslav N. Mezentsev
on 08/09/2018(UTC)
#9 Posted : 08 September 2018 23:43:26(UTC)
The hint is IGraphics.Unwrap<Graphics>(). After you've got native GDI+ Graphics object you can do what you need until API is updated according to your requirements. Currently all the plug-ins support .Net Framework 2.0 or later so they can be used for SMath Studio Desktop only.
I plan to allow plug-ins for other platforms and will extend API with all required by plug-ins, but it will be a bit later. For now this should be not an issue.
Please contact me by Skype in case of any questions.
Offline uni
#10 Posted : 09 September 2018 10:28:21(UTC)
uni
Ok, this trick helped me. But Release Manager makes the assembly which I can't install.
Russia ☭ forever
#11 Posted : 10 September 2018 00:32:43(UTC)
Thank you for updates!
I've just checked your NPlot, X-Y Plot and Zed Graph - everything works ok on my machine with latest SMath Studio.
Please could you provide some details about what happens on your environment. The most important change I did on build machine is that now system using MSBuild v.15 during compilation of plug-ins.
Edited by user 10 September 2018 00:36:07(UTC)  | Reason: Not specified
Offline uni
#12 Posted : 10 September 2018 07:08:32(UTC)
uni
Russia ☭ forever
Offline uni
#13 Posted : 10 September 2018 07:15:12(UTC)
uni
It was SMath Studio 0.99.6823. Now it works fine.
Russia ☭ forever
Offline mkraska
#14 Posted : 11 September 2018 03:03:44(UTC)
mkraska
There seems to be a problem with the Insert menu entries. The controls entry is cloned with each installation of one of the controls.
#15 Posted : 11 September 2018 22:37:24(UTC)
Thank you! Fixed.
Offline ElSid
#16 Posted : 20 September 2018 18:05:11(UTC)
ElSid
The new text region is loaded, but fails. No update for Excel I/O
#17 Posted : 20 September 2018 19:24:09(UTC)
Seems that the WriterRegion assemblies are copied to the extension archive even if the msbuild projects is set to not do it... I'll check for workarounds...
Edited by user 22 September 2018 03:33:11(UTC)  | Reason: Not specified
Offline pdalet
#18 Posted : 22 September 2018 11:03:13(UTC)
pdalet
France, Metropolitan
Was thanked: 16 time(s) in 10 post(s)
I can't launch this new version 0.99.6824 on linux (Ubuntu 18.04 - mono 4.2.1)
Message diplayed:
Unhandled Exception:
System.Exception: Can't find a proper language file. Try to reinstall the program.
at SMath.Manager.SessionsManager.ReloadLanguages () <0x4155feb0 + 0x0017b> in <filename unknown>:0
at SMath.UI.SessionsManagerPaths.Create (System.String[] paths) <0x4154b9b0 + 0x0005b> in <filename unknown>:0
at SMath.UI.AppSettingsDesktop.Initialize (SMath.Manager.PluginsStatusEventHandler loaded) <0x41544960 + 0x0017b> in <filename unknown>:0
at SMath.UI.Desktop.Program. (System.String[] ) <0x414c1fb0 + 0x001c7> in <filename unknown>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.Exception: Can't find a proper language file. Try to reinstall the program.
Thanks
Philippe.
#19 Posted : 22 September 2018 11:26:58(UTC)
Hello Philippe,
this is a known bug and should be already solved in the next release (see here for testing)
Edited by user 22 September 2018 11:28:50(UTC)  | Reason: Not specified
