SMath Studio Forum
Questions
using lookup function not work in sqrt command
Joined: 16/05/2012(UTC) Posts: 10 Location: indonesia
hi all, i try using lookup function descirebed by admin, however it's not work in using sqrt commands. what a poblem? anybody can help? thx u
The problem is that "x" variable is a matrix with single element - pay attention on the brackets. Therefore, square root of a matrix is not defined in SMath. Try this:
x:mat(6,1,1)
sqrt(el(x,1))=2.4495
Regards, Radovan |
hi, when using lookup function the bracket are in matrix mode by default i can not using these extracted data from lookup function to make further calculation using sqrt commands thx u
Hi, there are two errors here is the file in the image: vlookup_debug.zipregards, w3b5urf3r |
Quote:use the "[" after typing "x" to add the vector index thx u for clearly explains the typing method in previously posted by Ommor, it cut down my times and complexity using too much multiple branch
SMath Studio Forum
Questions
