2 Pages<12
Offline Alex M.
#21 Posted : 25 April 2018 00:52:06(UTC)
Alex M.
Hi Jean,
I get an error running your worksheet at variable "User".
I also managed to come up with stable solver for both neutral axis depth "na" and neutral axis rotation angle "alpha". Problem is it can take up to 20 seconds per single solution and i potentially need to run it ~50 times. Any pointers on speeding up function calls?
Thanks!
formulaR8.sm (283kb) downloaded 29 time(s).
#22 Posted : 25 April 2018 05:53:04(UTC)
Originally Posted by: Alex M. Go to Quoted Post
Hi Jean,
Thanks!
I lost track of the project as finally the bilinear interpolation solves for both mutually.
Pretty easy to construct the data table wrt "na" & "alpha". Try yourself, if not sure,
please give me the respective ranges. The bilinear data table needs not be square.
It can be rectangular horizontal/vertical.
Cheers Alex ... Jean
Project_0 Biaxial Bilinear [jmG] Copy.sm (116kb) downloaded 20 time(s).
#23 Posted : 25 April 2018 06:21:52(UTC)
... an otherwise bi-linear demo.
Bi-linear linterp interpolation has the virtue of quadratic.
QuadraticSplineCreateMesh.sm (16kb) downloaded 27 time(s).
2 Pages<12
