Offline Andrey Ivashov
#1 Posted : 25 February 2012 20:45:42(UTC)
Was thanked: 2011 time(s) in 679 post(s)
New SMath Studio 0.92 Stable available
Absolutely free mathematical program with "paper"-like interface and numerous computing features (now with integrated mathematical reference book).
SMath Studio Desktop on the Desktop (Windows)
SMath Studio Desktop on the Desktop (Linux)
Last changes
  • Printing bounds displaying implemented directly on the worksheet;
  • Printing improved: added ability to specify pages to print, print current page only (the page where cursor is located) or to print a selection;
  • Context Menu items now also added to Edit button of the Main Menu;
  • Graph animations performance improved up to 20%;
  • Calculations performance improved;
  • Program will now cancel any try to copy selected regions to the same location as initial using Ctrl key;
  • Current Region (Region with cursor inside) is now always shown on top (z-index) of others;
  • Hiding of the error when removing a region fixed;
  • Improved showing of the current error status of the Region;
  • Print preview dialog improved;
  • Plot Region error handling improved;
  • Added internal support for color and alignment of the Header and Footer text on print out;
  • Fixed critical error appeared when pressing on the Graph related buttons from Plot Math Panel if no Plot Region focused;
  • Fixed math panels issues appeared when screen DPI not equal to 96;
  • Fixed infinite loop issue appears for complex functions when math error occurs inside;
  • Fixed blinking of the Separator Region on worksheet horizontal scroll;
  • Several issues fixed appeared when non-standard Worksheet's scaling used;
  • Fixed drawing issue appeared on Grid displaying property changed when two or more Worksheets are shown side by side within one instance of the program;
  • Fixed error of the Symbolic Library appears when working with Units for expressions with numeric optimization;
  • Changing of the latin symbol to greek one or vice versa using Ctrl+G repaired for Text Region;
  • Fixed error appears on printing of the large Regions;
  • Fixed critical error on program startup when any of snippets has no Title set by File > Properties;
  • Couple of issues fixed regarding copying of content close to the collapsed Area Region;
  • Fixed error popup animation issue (animated twice);
  • Fixed issue appeared some times on pasting content from clipboard: region was not visible till any other user's action;
  • Language files updated;
  • Refactoring.
System requirements
  • Desktop (Windows):
    Framework: .NET Framework 2.0
  • Desktop (Linux):
Interface languages
Desktop и Handheld (34 languages):
  • [BEL] Belarusian / Беларуская
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [IND] Indonesian / Bahasa Indonesia
  • [ITA] Italian / Italiano
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCC] Serbian (Latin) / Srpski
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SRP] Serbian (Cyrillic) / Српски
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrain / Українська
    Free Download
    Note: No SMath Studio Handheld 0.92 release will be introduced. Please use the latest stable handheld version (0.90).
    Tutorial
    • SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
    Other files
    SMath Studio icons () of all available sizes (16x16, 24x24, 32x32, 48x48, 64x64, 96x96, 128x128, 256x256) in PNG format.
    Edited by user 25 February 2012 23:08:49(UTC)  | Reason: Not specified
  • thanks 3 users thanked Andrey Ivashov for this useful post.
    on 25/02/2012(UTC),  on 26/02/2012(UTC),  on 27/02/2012(UTC)
