Offline amit28it
#1 Posted : 06 January 2012 01:06:30(UTC)
amit28it
Rank: Member
Like calculator can we check which are prime and which are not in list of prime numbers to 100 and use of these nummbers a/c to runtime .Can you tell us this ? What the cause behind that?
Offline TheWizEd
#2 Posted : 08 January 2012 05:47:18(UTC)
TheWizEd
Was thanked: 19 time(s) in 13 post(s)
Not sure what your looking for but here is a simple routine to find prime numbers between 1 and 100.
Open in SMath Cloud
Does anyone know how to do if without else?
Edited by user 08 January 2012 05:48:49(UTC)  | Reason: Not specified
Ed
Offline omorr
#3 Posted : 08 January 2012 23:40:23(UTC)
omorr
Serbia
Hello Ed,
If I understood you well, you are asking for "if" without "else" because you needed this structure in your example above. As far as know, there is only one "if" structure, function in SMath, - "if" with 3 arguments. We could just make "if" function with two arguments this way:
Open in SMath Cloud
and use it in our worksheets. The drawback of this one is that the "if" defined this way can not have a "line" structure as a second argument (not quite sure about that) although the second argument could be a function call.
Open in SMath Cloud
I am not sure, but I think that Andrey can not make two "if" operators in programming palette. It would be a problem to distinguish them. I am not sure again, but I hope there would be possible to put if(2) and if(3) in the function list and, therefore, having both "if" structures - with and without "else".
Edited by user 09 January 2012 00:04:41(UTC)  | Reason: Not specified
