6 Pages«<23456>
Offline hanskl
#61 Posted : 03 November 2017 10:18:38(UTC)
hanskl
Norway
Was thanked: 7 time(s) in 5 post(s)
I have organized my worksheet somewhat now, and collected only the relevant parts for my specific problem at the top. The other stuff that although it displays the power of SMath - it's not relevant for this workbook, is gathered at the bottom.
Something mysterious, it does not download *.sm, only some sort of "Chrome" document.
Nothing to see, that's OK unless I can help more.
Cheers, Jean
That is certainly strange. When I try to download the file it opens just fine.
Maybe it's the use of the Scandinavian alphabet it the filename that's causing this.
Hopefully this works Smile
Staaltemperaturer ved brann.sm (740kb) downloaded 52 time(s).
thanks 2 users thanked hanskl for this useful post.
on 03/11/2017(UTC),  on 03/11/2017(UTC)
#62 Posted : 03 November 2017 15:52:33(UTC)
Works fine, thanks.
Offline hanskl
#63 Posted : 05 May 2018 02:55:01(UTC)
hanskl
Norway
Hi guys,
I'm back again with more headaches I'm hoping you can help me with.
The last time I wanted (we succeeded Clap ) to make a calculation for the temperature development of UNPROTECTED steel sections during fire.
This time I want to make a similar calculation for PROTECTED steel sections. Most of the work that was done on the last sheet is reused. However, the expressions for temperature development this time seems (to my eyes) to be a bit trickier. Crazy In the sheet I have pointed out where I am stuck. The image shows the example I am trying to follow.
Any help on this is greatly appreciated. Biggrin
Best regards,
Hans Kristian.
example.PNG Temperaturforlop i isolerte stalkonstruksjoner ved brann.sm (406kb) downloaded 26 time(s).
#64 Posted : 05 May 2018 17:23:07(UTC)
Hello ! Hans
Will be back on that soon ... cheers.
Offline hanskl
#65 Posted : 05 May 2018 18:00:56(UTC)
hanskl
Norway
Appreciated Jean!
I have added some graphic illustrations to highlight what is going on with some of the variables..
Best regards,
Temperaturforlop i isolerte stalkonstruksjoner ved brann.sm (416kb) downloaded 24 time(s).
Edited by user 05 May 2018 18:06:16(UTC)  | Reason: Not specified
#66 Posted : 07 May 2018 04:41:18(UTC)
All the graphs down to the DE solvers work fine ... but
======== the suite of 6671 is not compatible with 6179 ========
Simply disastrous that dn_GearsBDF 6179 is not compatible 6671.
The suite 6671 looks correct, sorry for this handicap.
Maybe more collab will terminate checking.
Cheers Hanski ... Jean
Temperaturforlop i isolerte stalkonstruksjoner ved brann page2.sm (58kb) downloaded 18 time(s).
#67 Posted : 07 May 2018 06:43:21(UTC)
... going back to your original 6671, the suite looks ok.
Not sure if I understand the meshing of the solvers from
the stacked "res"... missed something in there.
See you Norway ! ... Jean
Temperaturforlop i isolerte stalkonstruksjoner ved brann [Suite 6671].sm (479kb) downloaded 19 time(s).
#68 Posted : 07 May 2018 07:02:39(UTC)
... just a comment: "ainterp" is a very unique/specific cubic interpolator.
From applied analysis, it ranks from best to pure crap.
Your DE solvers are so dense, "linterp" is sufficient.
Offline hanskl
#69 Posted : 07 May 2018 09:39:09(UTC)
hanskl
Norway
Jean,
I must be missing something.. I tried to downgrade to suite 6671, and dn_GearsBDF still tells me it cannot calculate.
I don't understand why the DE cant handle e^ø. Or have I constructed the DE wrong?
Best regards,
Offline hanskl
#70 Posted : 07 May 2018 09:41:17(UTC)
hanskl
Norway
I'm not following you.. what do you mean? Smile
Best regards,
#71 Posted : 07 May 2018 16:22:45(UTC)
Jean,
The books style are very difficult to put it executable.
Your DE setup looks quite correct: proof the first one works
but the 2, 3, 4 "Division by 0". It must have to do with the
meshing of the Solver. It does not like something in there.
Should work in your latest 6671.
I simply reconstructed piece wise, simplified, on my 6179.
See U tonight ... Jean
Temperaturforlop i isolerte stalkonstruksjoner ved brann page2 fixed.sm (270kb) downloaded 25 time(s).
You mean you downgraded 6179
Offline hanskl
#72 Posted : 07 May 2018 22:00:25(UTC)
hanskl
Norway
Jean,
Jean,
I can not get it to work in my current version of Smath.
Is it possible another solver has to be used? One of the Runge-Kutta versions maybe?
You are quite right though, the fact that the first of the four equations work on your sheet suggests that it should work. However, that values in the solution you posted is quite wrong... Not quite sure why that is though, has to be something with the input.
I'm quite curious as to what the workaround/solution to this project will be. Looking forward to seeing what you will come up with Smile
Best regards,
Hans Kristian
#73 Posted : 08 May 2018 06:47:40(UTC)
Jean,
Hanski,
A bit of headache
Those solver may fails ... guess the cause "Division by zero".
You should have the first segment running as the picture.
Just to show how difficult it could be, read the ODE Yuk.
Temperaturforlop Compactum.sm (61kb) downloaded 20 time(s).
#74 Posted : 08 May 2018 06:52:39(UTC)
A bit of headache
Forgot to add: possibly a piece wise Finite Differences
will do. Just a matter of setting it correctly. That will
not "divide by zero " !
Offline hanskl
#75 Posted : 08 May 2018 09:36:45(UTC)
hanskl
Norway
Jean,
Hanski,
A bit of headache
Do you have a link to that text?
All the solutions works just fine if the last part e^ø(theta) is neglected. The DE solver can handle ø(theta) in the first part of the expression.
As a matter of fact, if the last part of the expression is altered to e^ø(t), the solver can handle that too. Of course the results are wrong, but it might suggest that the thing that the solver dislikes is the fact the e^ø is dependent on theta.
Is Mathcad able to handle this DE? Can anyone try to solve it there? Help
PS: I still cant get the original sol_1 to calculate in my version of Smath. It just tells med "Cannot calculate". If you get the error "Division by zero", maybe you can try to modify the IC's a little bit? From 600 to 595/605, from 735 to 730/740 etc.
Best regards,
Hans Kristian
ODE.PNG Temperaturforlop i isolerte stalkonstruksjoner ved brann.sm (418kb) downloaded 13 time(s).
Edit:
Does sol_4 work for you? It should work considering Ca is constant for this solution.
Edited by user 08 May 2018 09:53:05(UTC)  | Reason: Not specified
#76 Posted : 08 May 2018 14:12:25(UTC)
... Oh ! it didn't upload.
17 solvers, only rkfixed responds at very specific 'N'
ODE Yuk.sm (28kb) downloaded 23 time(s).
#77 Posted : 09 May 2018 04:44:00(UTC)
I doubt because rkfixed, Rkadapt are same.
The first segment maybe ? from the "Stiff option"
Good news is that the project has an elegant solution.
It consists in solving the Integral Equation
Will post it before bed time ...
#78 Posted : 09 May 2018 06:03:51(UTC)
... maybe there is some applicable scaling factor ? ?
Temperaturforlop Compactum Copy.sm (49kb) downloaded 18 time(s).
Offline hanskl
#79 Posted : 09 May 2018 10:31:13(UTC)
hanskl
Norway
Interesting! I will look into this later this evening!
But from the top of my head - the X-axis should represent time in minutes, not temperature.
Also, it took quite some time for the sheet to finish calculating. Huh
Best regards,
Hans Kristian
Edited by user 09 May 2018 10:42:05(UTC)  | Reason: Not specified
#80 Posted : 09 May 2018 16:55:01(UTC)
Best regards,
Hans Kristian
1. You can leave it in native 't'
2. the default Integration accuracy is 100, set it 50
it will have no influence in this application but much faster.
1.7 min in my 1.66 GHz laptop runs 225 greedy maths.
3. Does your version bracket t:=[0,5..600] ?
rather than Smath 6179 t:=0,5..600
Temperaturforlop Compactum Copy.sm (54kb) downloaded 21 time(s).
6 Pages«<23456>
