  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,343   Was thanked: 1175 time(s) in 677 post(s)
You can use only one command as a parameter to a function maple(). So you can't use the command with(). I have added to the archive file with.inc, it will connect every time when you run maple(). Archive: MapleWrapper_20130425.zip P.S. Another way.  Edited by user 26 April 2013 12:44:23(UTC)
One example. with.inc: Code:restart:with(linalg):with(inttrans):
 Edited by user 26 April 2013 11:17:17(UTC)
on 25/04/2013(UTC), on 25/04/2013(UTC)
Hi Uni, Thank you but it doesn't work for me. I can see the correct answer in mvr5.txt but Smath showed this error, s is not defined.  Originally Posted by: uni  One example. with.inc: Code:restart:with(linalg):with(inttrans):
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,533   Location: Italy Was thanked: 1269 time(s) in 834 post(s)
Originally Posted by: kaka  Hi Uni, Thank you but it doesn't work for me. I can see the correct answer in mvr5.txt but Smath showed this error, s is not defined.
Have you used the symbolic evaluation? Right-button mouse click and set the optimization option to "Symbolic" regards, w3b5urf3r |
Yes, you must use the symbolic evaluation ( -> ) but not numerical ( = ). In my examples used symbolic evaluation, it is not visible because I changed the view of symbol (from -> to =). P.S. I can't find now how to change the view of the equal sign. Apparently it was removed in newer versions. For symbolic output you need to press [Ctrl] + [.]. Edited by user 26 April 2013 11:43:43(UTC)
Originally Posted by: uni  P.S. I can't find now how to change the view of the equal sign. Apparently it was removed in newer versions. For symbolic output you need to press [Ctrl] + [.]. The arrow was removed in the 0.91 relase; I think that would be useful to visually distinguish between optimiztions, maybe with a little "S" in the top-right corner or over the equal sign.... Edited by user 26 April 2013 15:01:02(UTC)
Originally Posted by: uni  Yes, you must use the symbolic evaluation ( -> ) but not numerical ( = ). In my examples used symbolic evaluation, it is not visible because I changed the view of symbol (from -> to =).
P.S. I can't find now how to change the view of the equal sign. Apparently it was removed in newer versions. For symbolic output you need to press [Ctrl] + [.].  Finally it works now
Originally Posted by: mkraska  Hello,
the maple plugin seems to be partially incompatible with ; and , settings. For me, with , and . the examples work, with ; and , see attached image (generated with plugin version 2012 10 06). Unfortunately I can't remember if I had that problem earlier. Browsing the forum topic I found that there were times that ; and , was the default setting, that seems to have changed.
Switching to , and . is an option in particular cases, but I am writing a handbook in german that entirely demands and assumes ; and , settings.
Best regards, Martin Kraska Updated. Try again. |
on 02/05/2013(UTC), on 03/05/2013(UTC)
Joined: 19/04/2013(UTC) Posts: 46   Location: Podkarpackie, Poland Was thanked: 7 time(s) in 7 post(s)
Hello Uni,
Finally the MapleWrapper_20130502 works for me. Thank you for this new version.
Greetings!
Joined: 15/04/2012(UTC) Posts: 1,777  Was thanked: 980 time(s) in 625 post(s)
Originally Posted by: uni  Updated. Try again.
Much better than before. Thank you for the great work. I tried the examples: parse.sm generates formatting problems, the error message says that "Index and length have to refer to a position in the string" in MapleWrapper_Examples, all functions involving strings fail with the same error message, everything else is fine. mkraska attached the following image(s): |
Originally Posted by: mkraska  Originally Posted by: uni  Updated. Try again.
Much better than before. Thank you for the great work. I tried the examples: parse.sm generates formatting problems, the error message says that "Index and length have to refer to a position in the string" in MapleWrapper_Examples, all functions involving strings fail with the same error message, everything else is fine. Yes, this problem is present. I haven't found a good way to make the parsing more flexible. Working on it. |
Hello! I got an error like in this example below:  Regards, Janusz [Moderator]: Moved.Edited by moderator 04 May 2013 02:43:24(UTC)
  Rank: Administration Groups: Registered, Administrators, Advanced Member Joined: 23/06/2009(UTC) Posts: 1,740   Was thanked: 318 time(s) in 268 post(s)
Hello Janusz,
That's strange. I can not reproduce this. It works for me.
Regards, Radovan |
I confirm that. The error message is "Error, (in smath_diff) wrong number (or type) of parameters in function diff|ans" This error does not happen with . as dec separator and , as arg separator. Thus we have still localization problems with maplewrapper.
Originally Posted by: mkraska  I confirm that. The error message is "Error, (in smath_diff) wrong number (or type) of parameters in function diff|ans" This error does not happen with . as dec separator and , as arg separator. Thus we have still localization problems with maplewrapper.
It seems you are right Martin. One more confirmation that this problem still persist, in spite of unis' efforts. Regards, Radovan Edited by user 04 May 2013 02:20:32(UTC)
I specially do output to a log file. It is desirable in all such cases to show the contents of the file \plugins\mvr5\mvr5.txt. |
Originally Posted by: uni  I specially do output to a log file. It is desirable in all such cases to show the contents of the file \plugins\mvr5\mvr5.txt. Here you are. File Attachment(s): mkraska attached the following image(s): |
I think that the latest posts should be moved in the MapleWrapper thread to avoid confusion for Andrey on debugging SMath.  |
Try to use the el() function instead of a point: maple(diff(diff(f(x);el(x;1));el(x;2))). Code:maple(diff(diff(f(x);el(x;1));el(x;2))) - copy and paste to SMath Studio
In log file you will see: Code:[->] smath_diff(smath_diff(smath_el(x,1)^3+smath_el(x,2)^2,smath_el(x,2)),smath_el(x,1))
P.S. I didn't know that Maple understands this entry. I didn't plan to support this form of the equation.  Edited by user 04 May 2013 03:07:28(UTC)
Hello! Quote:I confirm that. The error message is "Error, (in smath_diff) wrong number (or type) of parameters in function diff|ans" This error does not happen with . as dec separator and , as arg separator. Thus we have still localization problems with maplewrapper. Martin, thank you for your explanations concerning this error, I made the change in settings SMath Studio - according to your advices, and all is already well. Regards, Janusz
