Offline Andrey Ivashov
#1 Posted : 18 February 2009 02:09:17(UTC)
An example of finding the greatest common divisor (gcd) in SMath Studio. This demonstrate functions: while, if and line.
(download an example)
#2 Posted : 18 February 2009 02:23:54(UTC)
Using of Simpson's rule with built-in SMath Studio functions. Example demonstrates work with user-defined parameters, functions and built-in function sum.
(download an exmple)
Offline omorr
#3 Posted : 06 July 2009 20:56:53(UTC)
omorr
Serbia
In addition, here is an example to show that one can have variable both limits of a definitive integral, by defining a function F(x,y)
It seems that the message "Limits must be real" should be regarded as a warning and not an error.
Offline omorr
#4 Posted : 06 July 2009 21:55:10(UTC)
omorr
Serbia
An example of finding function extremum (minima, maxima)
(dowload the file)
It is advisable to put the mouse on the expression because during the editing SMath sometimes does not understand what we wanted to do, for instance
It looks the same, but it is not the same function. If this is the case just type the equation again until you get what you wanted.
Similar Topics
Tutorial or examples for plugin development in linux? (Questions)
by fakemoses 22/10/2023 00:57:17(UTC)
Thiele f(x) Examples (Samples)
by Jean Giraud 19/01/2023 21:08:52(UTC)
Maple V Learning Guide examples via Smath Worksheet (Samples)
by johnspark 28/09/2021 10:10:58(UTC)
Bug - Examples - Properties of generic Polygons (Bugs & Problems)
by Alex M. 03/05/2019 00:01:18(UTC)
GivenFind Examples (Samples)
by Jean Giraud 20/12/2017 08:02:46(UTC)
LambertW Examples (Samples)
by Jean Giraud 25/08/2017 02:11:45(UTC)
Vectorize Examples (Samples)
by Jean Giraud 27/04/2017 03:58:10(UTC)
Fourier Examples (Samples)
by Jean Giraud 07/01/2016 05:23:11(UTC)
Examples of building equidistant line to the given curve (Samples)
by Ber7 31/05/2014 22:23:48(UTC)
Smath Examples Blue Variables (Questions)
by RFreund 26/03/2014 15:54:50(UTC)
overlapped regions when opening help examples (Bugs & Problems)
by kilele 07/04/2011 15:34:19(UTC)
Error with opening Help/Examples (Bugs & Problems)
by Eddy 11/02/2010 04:39:53(UTC)
